Guud fur youz. Und 2 da dummys up dare, it duz msake a differance. Dude is 2 cheap 2 try. Rent1 and take a trip down arode way 2 neva enden $$. Port, polish, blu print, snot bad fur da $$.
 Let me try and understand what you’re saying in English.
let me tell you this is not cheap.
the heads are ported with stronger valve springs and harden shafts
Had Johnson short travel lifters with axle oilers
Manton made for this engine push rods
Manton harden rocker shafts
Every bore and piston measured
Piston to wall Clarence checked
Every rod and Main checked for size plus bearing clearances check
End play checked
Every bolt tq to spec rod bolts done by stretch not by tq
Head studs redone after sitting 24 hours and will be redone again tonight
Maybe do some research on people and how they do things. Not one of my engines have Ben under 1050 wheel hp yet and all get pounded on
