- St. George
- UT
- 2016 Dodge Challenger Hellcat
- HFCOTM
- View Images
Hey Colby…. Some things that I was planning to chat with you about but if I ask the questions here maybe someone will learn a little about doing stuff at this level. Your block has been a full fill. I assume you’re still pumping water thru the heads. What pump are you using and how’s that working as far as temps go with the methanol? Going to the Dart.. I assume you are not going to do any filling with that block. Going to use the same pump and radiator? I also assume you guy have had a good look at the Dart. What do you think and any thoughts on Callis Hellephant vs that? Congrats on the accomplishment. Your team has their shit together for sure. 👍🏼
