IC Chiller install & review
catdad
Lake City
2019 Charger Hellcat
#41
Glad to see I'm not the only one that zip tied the insulation on the hoses. That was the worst part of the job.
U
Thread Starter #42
Hose came in. Decided heat exchanger is getting plugged off completely. If I change my mind, I’ll have plenty of hose left lol. Keeping the bugs on the condenser, adds character
U
Thread Starter #43
Glad to see I'm not the only one that zip tied the insulation on the hoses. That was the wort part of the job.
Is it even a race car is it doesn’t have zip ties on it? 😅
U
Thread Starter #44
Insulated good enough I’d say
Are you guys wrapping (insulating) all of your lines (too hot line included) or just the bottom cold line going into the supercharger?
I insulated everything including the pump housing.
U
Thread Starter #46
Oh wow. Do you know what the stuff is they use to cover the chillers/aux tanks? They’re rubber insulation in sheets? Looking for some of that
This just reminds me I need to re-do a bunch of mine.
One thing that Allpar didn't do was tuck it tight away from said alternator pulley. Oops. Lol
U
Thread Starter #48
Really? Did the alternator pulley chew it up?
U
Thread Starter #49
I also used the more expensive wrap which is smaller in diameter and bends/molds easy
McMaster Carr has adhesive backed foam insulation sheets, I used the 1/2” thick stuff
It self clearanced around the pulley. Plenty of room to the hard line. Probably an oversight as it may have been done with the cradle out of the car.
If that's the worst thing I find wrong it's a victory. My luck is not great when it comes to cars lol
looking good buddy!
U
Thread Starter #53
Welp, I need to get different fittings for the water lines into the brick. I received metal 90 degree fittings as opposed to the plastic ones I typically see with this kit, and they only want to thread in 1/4 of the way, stick down way too far, and will become too loose if I try to index them the way I need them. Anyone know where I can get plastic chemical/heat resistant plastic 90 degree 3/4 barb to npt fittings? They really need to put AN fittings on the brick.
U
Thread Starter #54
not trying to crack the brick by over tightening, and I know the plastic ones have more give/better seal. This is dry fitting without paste
Ace hardware, where I got all mine.
U
Thread Starter #56
U
Thread Starter #57
Also, did anyone put any lubricant in the ac fitting o rings / washers? If so, what did you use
I have the original plastic ones. I want to upgrade to brass or aluminum. The plastic ones don't stay tight. I have Teflon on them and all.
U
Thread Starter #59
I would stay away from the metal ones, they don’t thread in far enough and being npt you can’t tighten them any more. Plastic ones you can at least thread in most of the way depending on the stiffness of them without worrying about damaging the brick. Will be looking into possibly low profile NPT to AN swivel 90 degree fittings. Will probably stick down too far still, but I’ll be able to index hoses however I need without fittings getting loose
don't go plastic unless you have the time to keep tightening them and chasing small drips.
