Blown Motor Continued
Wanted to break this out since there's been so much discussion. I had a performance shop reach out to me over the weekend. They've had three Hellcats fail all around the 800rwhp mark on a Mustang dyno, all cylinder 7 like mine. They've had one Demon fail, 910rwhp from their Mustang dyno also cylinder 7. They've now started to recommend pistons/rods at anything over 800RWHP.
Octanewide
House of power
Oh boy lots of people out there running over 800rwhp on the stock long block.
Diboblo
Riverside
2015 Dodge Charger Hellcat!
Not surprising.
6.1 failure was prevalent, at about 600hp, in the early days.
Forged lower end solved that.
I suspect this will be the cure, going forward.
oilburner
coboconk
did they comment on what mods where done on the 3 hellcats an where they all the same, curious to know.:unsure:
So, are you thinking it’s more about hp than rpm, now? Did the performance shop mention the engine speeds when the others failed?
I still personally think it's RPM related. I'll ping them on that to see if they share that data.
Beast707
Carol Stream
2018 Challenger WB M6 Hellcat
Sub'd
Sub'd as well.
Blkout
Warner Robins
Would be helpful to know.
Demonic Cat
Speedy, 4 cat engines, including yours, and one Demon. Same bank, same, end cylinder, I know it’s being declared rod failure, but it at least has to cross ones mind why all # 7.
Your thoughts. Coincidence, or possibly something more. Not trying to put Negative hype on it but does beg the question.
South Florida
Speedy, did you have any cylinder misfires happening at WOT/high rpms and prior to your engine's failure?
DFW_Redeye
Dallas
2019 Hellcat Redeye Widebody
So is it safe to assume that the Demon/Redeye pistons are more stout and can handle 900 rwhp?
Markp
Fuck Trudeau
Something is definitely going on with cylinder 7s. Seems like even the majority of misfires are on cylinder 7. I would think that this is not a coincidence and is likely that all cylinder 7s are the weak link. Seems like someone made a error when designing the CAD/CAM program for machining. Could be a small mistake in the code on cylinder 7. Seems strange though that Hellcats and Demons both have a cylinder 7 issue. Can't make the same mistake twice?...can they?
https://www.hellcat.org/threads/p0307-code-at-201-miles.11957/
https://www.hellcat.org/threads/upd...der-7-misfire-codes-p0171-p0296.164889/page-2
https://www.hellcat.org/threads/cylinder-7-misfire.135121/
MiHiHemi
Parker
2015 Challenger SRT 426
I'd be curious on how the temp. of that cylinder compares to the rest at high revs. Sure looks like a pattern evolving.
PaVaSteeler
Mole
VA
following
Subscribed
JustForFun
Muscleville
cole3986
TBD
Pistons are weak on the Hellcat, mine did the same thing on a 8 second pass (well it ran 9.2 or 9.3 I forget) with a hole in the block. piston.jpg
cole3986
TBD
Speedy,
Real nice video
cole3986
TBD
