Thread Starter #1,441
Have a wiring diagram for 2015
chuck
I have a 16 so it’s probably the same. Can you email it to me or just post a picture of the fuel pressure sensor section?
Thread Starter #1,442
Nice!! Exactly what is needed but I need it on fuel pressure sensor itself.
My apologies I see it on the connector now that’s exactly what I needed. Thank you Fuman!!
You mean you guys don't lift the supercharger off yourself ??
I have put them back on by myself. My back was sore
Yeah forget that. Getting it off not terrible if you're careful and walk it to the front of the car on a mat, but putting it back on no way.
No direct test of sensor out put voltage sensor to sensor at same psi input but I think todays full throttle 6500 rpm 2440 aircharge data logs show something is different between the 2. pumps did not once go to 89% or fuel pressure go below commanded 73 psi, even in -500 DA, 39F, and 83% ethanol in the tank. I can test the RE sensor easily but testing the integrated into the fuel line HC sensor is going to be a challenge but I have an idea but need some injector clips to clip some injectors into the rails to plug the holes. Anyone have 4 clips they can send me?
@16GoManGoHC2 I have a stock fuel rail with sensor I’ll donate to this cause and stock injector clips if you can run the tests for us
What’s up with the http links not cool fuman
i dont fucking own the site, its also a god damn connector site that has zero financials behind it. Add the s if it makes you feel more secure, makes no difference to me, your computer is already “our” computer Comrade
Thread Starter #1,449
I have rails, let me check on the clips, I’ll look tonight.
Thread Starter #1,450
No clips, can someone send me 8? I can hook the HC and RE rails together and test at the same time. PM me for address to send them too. TU
Correction, I have stock injector clip (not clips) I can donate. No idea what happened to the others
Thread Starter #1,452
Thanks for looking at least!! I’ll look some more. I thought I had a set of stock ones around that had the clips with them still
autozone sells the clips. I had to get one last year after 1 went into the black hole
Thread Starter #1,454
Any idea on part number? Or did you just ask for clips to fit a xxxx year hellcat?
think I just looked it up. All late model hemi are the same I believe
Sorensen Rail Retainer
# 800-9410
2fast4u
Edwardsburg
I have a complete spare 2.4, if you need the clips, I could send what you need.
Wow they're proud of those clips!
I have recently been looking to the 100-150mph dragy times as trying to get traction at 60 on a street is impossible. It seems to be a better way to gauge accurate increases, for me at least. tried 3 times yesterday and spun to 80 on each attempt. sill seeing 4.7's. 60-130 spinning pretty bad. but the 4.13 100-150 tells a much better story.
G33ze @fumanchu182 i was just messing with ya man, just figured since you’re tech savvy ya would have added the s lol
