- Interwebs
- TN
- Demon 170
Hopefully my AAD Idler pulley mount modification works and I get it mounted tonight, get some more wrap on the pulley and tension on the belt and get some high rpm fueling and pump data soon.
The RE fuel sensor I can make a jig to test it pretty easily but the HC one being it’s part of the rail is going to be a bit more of a challenge without ruining a rail to cut one out of. And he want to have a donor HC DS rail they want to sacrifice to this experiment? I need the fuel pressure sender from one.
What size injectors? I bet your fuel pressure was really higher then displayed and the PCM thinks it is.
1
