"Project Demons Breath"
Thread Starter #1,781
That's a bit aggressive. I may cut the ball and socket off and use a wide band clamp .
Whatknot
OR
Agression is sometimes required lol 😉
I like welding, so my solution is often to grab little Lincoln.
Locking fastener.
Thread Starter #1,785
Locking fastener.
Something like Stage8 if they make?
The odd thing is the nuts are not backing off . The are lock nuts . I thing the flanges are deforming. I actually found a ball and socket band clamp . I ordered 2 of these in stainless. I really don't like the 3 bolt triangle flanges anyway . I will take some pics when I get them and show the difference.
That makes sense believe it or not.
I have had flanges bend on other cars causing leaks.
Thread Starter #1,787
Luckily it's not leaking but the bolts rattling are driving my know sensors crazy and it's hard to tune WOT.
Thread Starter #1,788
I would like you guy/gals to do something when you get time . I would like you to post back here your hot idle vacuum and oil pressure.
( engine thermostat open and in P on A8 or in neutral on M8 . )
This is for my curiosity.
@moparjim , @DemonSRT ,and @16GoManGoHC2 need not apply . ( sorry I couldn't resist )
oilburner
coboconk
spring kit
DemonSRT
Kawartha Lakes
:p & a FINGER.
That's all I got to say.:LOL:
Well out for some more testing . A couple of things . At 38F my car makes 19 psi ( 2.30 Pratio) and at 72F it makes 18 psi ( 2.25 Pratio ) . These are peak numbers . Also I see 18 inches of vacuum at hot idle . My car made the best of 16 inches before.
And those blasted header collector bolts loosened up AGAIN ! WTF I need to figure out a new way of connecting the headers to the exhaust.
A couple clean tack welds will work. Put them in a place where they are easy to grind or cut when necessary.
All these missing engines
oilburner
coboconk
ok Jim we want your blood pressure instead:geek: an your body temp every time you think about your car
It would have been interesting when I turned and first saw it. Especially after not expecting anything to be done. I was going to bring it home while we waited for news.
oilburner
coboconk
I hope your wait is not as long for a motor as a stupid demon caliper is.:mad:
What did I miss?
ECT at 183° F RPM around 700
Idle Oil Pressure 47-49 psi
Vacuum 10-12 in/Hg
Thread Starter #1,799
Moparjim's car is In getting a warranty engine .
Demonsrt is trying to upgrade his suspension and is having a hell of a time getting parts
And 16gomango had to rebuild his engine and is stuck waiting for parts so none of them can start their cars . I figured I'd throw a dig at them .
Thread Starter #1,800
Vacuum 10-12 in/Hg
Thanks . My car is idles around 725 so that would pick the vacuum up a bit
