Miss on Big End
Chuck
Auburn
2021 Redeye Super Stock
Thats the Problem did a brain fart and forgot laptop and my hp tuner
any update?
Chuck
Auburn
Talked to Fore they said my fuel pumps are at the end of there life
Waiting on the last pump should be here tomorrow
put new plugs in switched back to old coils
Removed two step
We shall see going to track on the 19th remembering to take laptop and tuner
Sensor damage, tune out of whack, any pieces of it make it into the exhaust?
EDIT - just got to end of thread. Never mind.
Chuck
Auburn
Still battling this problem I'm at the end of my rope anybody got any more ideas ? went to track and remembered my laptop this time at 87 mph from what I see the left o2 sensor goes to zero and stays that way until problem stops now Im not vary computer savvy and reading all these squiggly lines I'm for the most part lost if anybody wants to see logs PM me I will send to you
Thanks for any help given
Thanks Chuck
send me your log and I'll take a look
Does it only do the miss at the track or in other acceleration situations, like passing, merging, on ramp, etc...
Chuck
Auburn
Mainly 6000 rpms where I have noticed it
Starts at 87mph and continues until the end of the run, so the problem isn't married to RPMs, since you'd shift a time or 2 before the end of the track and would cover a wide range of RPM. It also takes a few seconds or minutes to clear up but clears up on its own. If you shut down at the end of a pass and read the plugs - are they still good? If you shut down at the end of a pass, will the car start and drive normally or do you still have to wait?
Does anything else happen around that time? Are you electronically controlling anything by speed or gear? Boost for example.
This all started when the belt shredded, right? Ever find root cause for the belt failure?
I'd look for damaged wires around the belt area. At lower speeds the frayed wire may be making enough contact to work, but once there's 100mph worth of air blowing on it, she opens up and loses connection. Slim chance, I know, but there isn't a lot going on that's speed dependent. No ABS or Traction Control stuff happening right? Those can be speed dependent.
Marc0779
Key largo
Redeye/demon
last week I shredded my belt some material got sucked into ProCharger since that happpened I have had a miss on the big end it will usually will clear up by the time I get back to the pits.Trap speeds have dropped substantially
I get engine code P0300 Multiple cylinder missfire
I pulled inter cooler and cleaned it out pulled all plugs they clean and burning correctly. Di a compression check 175-185.
Bore scoped everything looks real good
anybody have any ideas ( can lifters overpump ?)
I have an email to Curt waiting for a responce this week.
Thanks Chuck
Thanks Chuck
I have had procharged cars in the past and if the belt is slipping at wot it will run rich and missfire,see if you can log it it could be your problem,its tuned for a boost number without belt slip.
Chuck
Auburn
Not going rich it is going lean
Thanks for your input
Chuck
Chuck
Auburn
Yes car clears up on its own
Plugs have a good color to them
The car starts right up after run and drives normal it does have a gear vendor makes no difference on or off
there is no other symptoms other than the miss and goes lean
Checked all the wiring and connectors no bare wires all click locks snapped on sensors
I have the traction control tuned off by holding button for 10 seconds or so
Chuck
Logs def showed a lean condition. What about fuel filter socks? It sure looks to me like a fuel delivery issue.
Chuck
Auburn
Had pumps out socks clean if you look at log 2 towards the top fuel pressure is in the channels 45-80 depending on boost
Log 2 showed no issues. Fuel pressure was not in Log 1.
Chuck
Auburn
Log 1 did not have fuel pressure installed
log 2 towards the end after the 107 mph and speed started to come down went lean for over a minute and was missing the entire minute
Chuck
Auburn
Took it out today and can reproduce in any gear with rpm Just need to bring rpms to 5500-6000
So off throttle the car goes in to decel fuel cut off, so you're wide band will show max at that point, usually 18 for AFR. On throttle is where you don't ever want to see that happen. 11.5 - 11.8 on gasoline is the range. I'm diagnosing over the internet, but I'm highly confident you've got some kind of fuel issue.
It may be fuel injectors, have them cleaned or replace.
F1 has some awesome injectors & fairly inexpensive, talk to Keith 832-997-6065.
If you buy his injectors you get 1/2 price cleaning when needed, and their all flow matched.
Chuck
Auburn
Yes that is what is happening it’s like a switch turns on and a while later it switches off and runs fine that’s why it’s got me stumped not computer savvy I guess I could go ask my 5 year old grand daughter
