Miss on Big End
Chuck
Auburn
2021 Redeye Super Stock
last week I shredded my belt some material got sucked into ProCharger since that happpened I have had a miss on the big end it will usually will clear up by the time I get back to the pits.Trap speeds have dropped substantially
I get engine code P0300 Multiple cylinder missfire
I pulled inter cooler and cleaned it out pulled all plugs they clean and burning correctly. Di a compression check 175-185.
Bore scoped everything looks real good
anybody have any ideas ( can lifters overpump ?)
I have an email to Curt waiting for a responce this week.
Thanks Chuck
Do you have a sense for how big the pieces of belt were that were ingested?
Bent valve causing misfires (although compression test would seem to rule that out)
No air filter on procharger, why? You can get a P0300 if it is only one cylinder misfiring
All the plugs looked good?
Chuck
Chuck
Auburn
I I’m running E85 it has a screen on intake of Procharger if I put air cleaner on I loose 7lbs of boost to many elbows cuts air volume.
plugs looked real good all were tan colored.
it was definitely more than one cylinder it would hardly pull away from time ticket shed.
bore scoped all cylinders looked real good and so did valves.
funny part is within 300 feet it clears up and runs great
Have a pic of engine? I ran Vortech's for many years on Mustangs and never seen a 7 lbs drop with an air filter. Thinking a different filter?
I wonder if some of the fins on the procharger impeller got bent ?
Chuck
Chuck
Auburn
Curt did the tune on it and the increase was substantial when he pulled air filter
Chuck
Chuck
Auburn
That is one thing I haven’t checked is the fins on procharger
There may be a external & internal impeller ? ... if so you may have to take it apart & check both, for bent or cracked fins.
Bent fins wouldn't cause a miss just less flow. Check all the inlet piping and throttle body for any broken sensors
I would check anyway.
Starving for air because a tune is so far out of wack, causing a cylinder to go super rich???
Are the Cats (do you have Cats???) running hot?
Chuck
Chuck
Auburn
melted cats so gutted them a while back
already pulled all tubing and throttle body everything clean
weird thing is it is doing the exact same thing every pass 15 passes.
Chuck
Chuck
Auburn
Checked fins on impeller none bent or worn
Did you just look from the outside or did you open it up & look inside too ?
Chuck
Chuck
Auburn
Pulled rear housing to look at whole impeller
Did you take the s/c lid off to see if any of the belt material is on top of the intercooler bricks ?
Chuck
Chuck
Auburn
Thread Starter #18
Yes pulled intercooler out of car and cleaned with air downward
doesn’t have a S.C. lid
Oh yeah, my bad, I was thinking of HC s/c, lol.
I understand that it's throwing a code, but what is the log telling you?
