20x7 Front and 17x11 Rear Widebody Challenger
HRJ
Porsche GT3
Edit - changed the title to include both ends of the car. Also edited to include all information on the parts I bought to do this.
What's the specs to order these front wheels for a Hellcat (6 piston Brembo)? Also, what tires go on them?
Thanks.
EDIT - Done. Parts list below
Wheels, Weld S71
20x7 Front - p/n 71HB0070W38A
17x11 Rear - p/n 71MB7110W58A
Front Spacers, ZL1Addons
3mm
Extended Wheels studs (required for front, I did both frt and rr), Dorman
14mmx1.5 - p/n 610-509
Lug nuts, Gorilla
14mmx1.5 - p/n 78644n
Rear tires, Mickey Thompson
ET Street R - 315/50r17
Front Tires, Bridgestone
Potenza S001-I - 195/50R20
This is going to be neat!
HRJ
HRJ
Porsche GT3
I hope so. Can't seem to find this info anywhere, though.
motorhead
Ottawa
2019 Challenger HC Widebody
Cool. You guys can run the tires off of a BMW i3.
HRJ
HRJ
Porsche GT3
Maybe, I guess. Dunno if the load rating is gonna fly.
Found this pic on the ol' webz. Can't make out the details on the sidewall other than it's a Bridgestone Potenza.
HRJ
HRJ
Porsche GT3
Got an answer back from Weld. 20x7, 4.2" backspace and High Pad and requires an 1/8" spacer.
Now to figure out that tire....
CORRECTION:
- The fitment above is for a narrow-body Hellcat.
- Widebody Hellcat 20x7 fronts come in two options... High Pad, 2.25" backspace and -45 offset OR a High Pad, 3.8" backspace and -6 offset. The 2.25" BS wheels fit flush with the fender, but have the wrong offset/scrub radius. The 3.8" BS wheels have the correct offset but sit inboard 2" from the fender.
- Both wheels require a 1/8" spacer.
I'm picking the 3.8" BS version. Would rather have the car drive better and don't mind the wheel being recessed into the fender.
Decay
Astoria
OR
2019 widebody Redeye
Got an answer back from Weld. 20x7, 4.2" backspace and High Pad.
Did Weld have a suggestion on the tire?
HRJ
HRJ
Porsche GT3
Unfortunately, they didn't answer that question.
HRJ
HRJ
Porsche GT3
I made a correction in my post above on fitment. Weld specs out different offsets/backspacing on Narrow and Wide body cars.
Same choice I would have made. you planning on that being track only, or are you going to drive around innocently with skinnies on the front on the street?
HRJ
HRJ
Porsche GT3
It'll see some street. Not all the time, but there are times that I'll be on them out in the world. That's why I wanna do the 20x7 S71s. Should be more durable than a track-only 18x5 and handle better. Won't be as light, but will be lighter than the factory 20x11s.
Best Vapor
Valrico
You sure on that 1/8 spacer I have them on my non wide body Challenger Hellcat with no spacers 20x7
HRJ
HRJ
Porsche GT3
Not 100% sure till I go to bolt them up. Weld's fitment guide said it was required...guess we'll see.
HRJ
HRJ
Porsche GT3
The Welds should arrive today according to FedEx. w00t!
Now I just need to measure ID to order my hub-centric rings. I'll unbox them and post pics when they hit.
HRJ
HRJ
Porsche GT3
I cant read....delivery will actually be tomorrow.
What is your BS & offset on your 20x7's ?
Pics. ?
Pics, of course
HRJ
HRJ
Porsche GT3
37A2A214-6605-4BF5-A489-D3B7AAC38AD0.jpeg 1AE1B982-5E82-461F-B820-A84FEDCB005F.jpeg C1B31D02-7445-4980-8E77-EDF7BF204DCF.jpeg
son of bitch, that's pretty.
