- Interwebs
- TN
- Demon 170
I've questioned what the issue is with the orange tint from MMT. I did some reading on it a while back. There was a thread on the other forum from a guy that put Boostane in every tank and a year later gave an update. No fouled plugs or any sensor issues and he used it EVERY tank for a year according to his report. I have about a half can left in my cabinet in the shop from where I tested it. It does work.
@motorhead brings up a point about consistency though. In my opinion, most folks just aren't disciplined enough to insure they have the same amount of fuel in the car each time, etc. I'm anal about these types of things so no big deal to me, but your average joe just wants to show up to the track with whatever amount of fuel is in the tank and dump in a can of this stuff. That may be OK, but it may not be. I'd rather be sure and know exactly what my octane should be based on the mix.
I use alcohol (methanol) injection very successfully on my non-intercooled supercharged 2002 4Runner. Adding that system gave me back 7-8 degrees of timing and the truck runs very well. It took me a while to get the nozzle size and alcohol mixture figured out to avoid bogging down low and provide proper AFR up top though, and again this requires a bit of OCD to keep it consistent. On a Hellcat with it's wideband sensors, I'm not sure how well it would work. I'm thinking the car would start to pull fuel from the injectors to compensate for the extra fuel the injection would provide. Maybe not a big deal if you got it setup right, but definitely something to be aware of since the Hellcat is wideband all the time rather than open/closed loop like older cars.
