I need a Long Handle Torque Wrench
22RENBS2 & 170
Yeah, I'm old, tired everything hurts, etc....
My back is staring to bother me after using my 18" torque wrench. There are many available that are 24" which decreases effort only 33%. I am looking at this one, it is almost 30" so it would reduce force about 40%. Anyone have any better suggestions?
https://www.amazon.com/CRAFTSMAN-To...+handle+torque+wrench+1/2,aps,154&sr=8-8&th=1
I bought the Quinn one from Harbor Freight a while back and been happy.
MJS73
Moparland
2020 Challenger Hellcat
Pretty low tooth count on that Craftsman. At 30” you run out of runway pretty quickly in tight places. If it’s just for lug nuts, you have all the room in the world, doesn’t matter, but consider more while you’re shopping.
22RENBS2 & 170
I looked at that yesterday, 24", much better than what I have. If don't find something better I figured I'd wait for the next 20% off coupon.
Remember, I'm an old guy! I have a couple decades on you! I need things to be easier! :)
22RENBS2 & 170
Yes, lug nuts. I have the short one for other jobs. And thanks, I didn't notice it was only 32 teeth! The Quinn is 72!
Can you just slip a length of metal pipe over the handle ?
That's what I would do....surprised 2nd Amend guy didn't think of that...(after all he always says he's cheap)[wrenchin]
What we did in the army when torquing the Jesus nut (with a ft lb torque wrench) was slide a 3 ft pipe over the handle, made that double click allot easier
For lug nuts, just lean your weight over it. 130 lb ft is easy, even on a relatively short torque wrench.
I also have the Quinn digital 1/2", love it. I will be getting all of the Milwaukee click type when they come out this year though
This works good
Especially with 2 bad shoulders & the shakes
22RENBS2 & 170
I do that with the breaker bar to loosen them, I have a tube that fits perfectly snug.
Every torque wrench I have seen does not have a nice cylindrical grip like the breaker bar. In that case it is a PITFA dealing with 2 loose fitting parts, not worth the trouble. Turns a 2min job into a 10min job.
22RENBS2 & 170
When I worked at the a/c company, management issued a directive banning certian common terms, two I remember were "Jesus Nut" and "Chinese Hat". :ROFLMAO:
22RENBS2 & 170
I never like pushing on a wrench, especially a deep socket with an extension.
22RENBS2 & 170
My current 18" has a big hex at the far end of the grip that is part of the adjustment lock so it is a lousy candidate for a tube extension. I'll look around, maybe I can find a 24" that is more suitable. If I can make an extension that clamps tightly (maybe weld) that might work. I can just leave the extension on all the time and use the 18" as the portable.
It seems like a 30" might get me close, even if it is only 36 tooth.
This is only for lug nuts, and I have 3 trailers with 10 wheels total, plus 4 vehicles. I do all my own maintenance, swap wheels/tires for racing and winter. Anything better than the 18" would be a big help.
Thanks for the suggestions!
2ndgen
Orem
Just get one of these sets. They work great.
First exercises every time I still workout are what appears like worthless arm motions but are specific to the rotator cuff. Shit I only use 10 lbs on that stack, but for this exercise it is plenty. Best thing I have ever done. Started it four years ago when they replaced my right shoulder.
These pictures suck but do the exercise using a vertical stack both towards the inside and the opposite way out - seems harder. That helps pulling the damn wrenches. Ha, along with my big Milwaukee 2767. I am a lucky man, inherited a truckload of tools from my Dad who did machine maintenance at a tire plant. Besides a beautiful 24”, I got lots of other weapons in my garage for the stubborn shit.
22RENBS2 & 170
Thanks, I'll give that a try. I'm falling apart, way more than just the shoulder. And then I pulled a muscle in my back 2 weeks ago and it has not improved since. It's like everything hit me at once this year.
Lowes has the 30" in stock for $70, I'll swing by today for a look.
Sorry my friend. In that regard getting more senior sucks! 30” should help, but like is said above you will need lots of room to use that sucker. I am like you, last week simply installing chains requires a couple of my favorite pliers because my left hand has suffered from a couple of nerve problems and just does not have the strength it should. Sometimes life in the garage is a constant “work around”. Good luck.
