Build progress
Thread Starter #121
It’s the back part that’s touching. Before I torque them down and crush the gasket, I want to make sure that’s going to be enough room for engine movement. If now, it comes out and I grab the sledge hammer to beat that rib in.
Thread Starter #122
I have 1/4” spacers dropping my cradle. I think it would be worse without the spacer in the cradle. I could possible loosen the trans crossmember and see if I can shift the engine over a little, since it because more narrow on the passenger side as you go to the back. Open to suggestions l, appreciate it
Thread Starter #123
I see @16GoManGoHC2 lurking, maybe he has some thoughts 🤔
Thread Starter #124
My JBA 1 7/8” Cat Forward CARB approved shortie headers (yes, my 1050-1100 wheel M6 is fully emission's compliant yet lol) and they only had about 1/8” of clearance to the tower ribs on both sides of the engine. The engine will torque over towards the passenger side under load and most likely hit the rib. I put a hard wood wedge about 3/4” wide with rounded edges and shape on the tube side between the rib and the header tube from underneath, both sides at the same time so engine just didn’t move side to side and forced them up (with a hammer and long drift to get at them from bottom side) together which flattened the header tube slightly giving clearance. It was in the perfect place and looked “factory made” into the tube with a rounded impression which most likely does not effect flow in that tube at all but gave me 1/4” of clearance each side in just the right place without beating in the car ( that rib will not flatten easy). If the tube rubs it will rub through with time and also may be picked up by the knock sensor if banging off that rib under WOT and cause false knock and unnecessary timing pulls. My O2 and suggestion.
Thread Starter #126
Thanks @16GoManGoHC2. The engine torquing to that side and it being picked up by the knock sensor is my concern. I have tons of clearance on the driver side - passenger seems to be the issue. These are thicker gaskets, I have a set of new stock ones, but am concerned with leaks. I’d rather knock that rib in than the header, the hard wood wedge is a great idea though. I have at least 1/4” on driver side, maybe more. Hmm, I’ll have to put some thought into this. So much for bolt on, was expecting better quality control from kooks and a direct fit, which is why you pay more for these over other headers
Thread Starter #127
I’m cutting portions of those ribs off. Picked up some solid carbide 1/4” burrs for my die grinder. Now I have 2 choices. Bathe in sparks from my mini death wheel, or metal shavings/dust from die grinder.
Be sure to wear your safety squints.
Thread Starter #129
got goggles and a face shield, since I had to do it on my back right over my face. Still somehow got a hot piece of metal on my eyelid. Stuff was tough as nails to cut through even with cutoff wheel. Should have enough clearance now
Thread Starter #130
Plenty of room in the back now. Front is still really close, just couldn’t get in there to cut it
Call kooks yet and ask?
Thread Starter #132
Ask what? If it doesn’t fit it doesn’t fit
If it's normal for it not to fit
C'mon...Holy guy ain't gonna do that...he's just gonna break out the hammer...chisel ...and torches...:giggle::giggle::giggle:;)
Thread Starter #135
It’s aftermarket, that’s how it goes
That's a crazy notion...just think if all the headers they produced ...didn't fit...even you should be able to figure out...something is wrong here
Thread Starter #137
Yeah, they’re “exclusive” C/B grade headers for a reason apparently. Collaboration with another company. Few factors, I’m using thicker gaskets because I’m not pulling these again after it’s back together. The other is I have my cradle lowered 1/4”. But you’d think with slightly thicker gaskets there would be more room than that
Thread Starter #138
Called HHP. Said they’re only ever to get 1/4” and some are real tight. When it is, they bash the ribs flat. Not possible for me with the engine and cradle in the car, and the engine can’t be shifted over.
Just something about the thought of BASHING anything with a hammer on my car to make it fit:eek::eek:
Thread Starter #140
Which is why we are not the same
