3.8 whipple cold air intake. Wtf
Hatermkr
West bend
2016 helldemon
So you buy a 3.8 kit comes with no cold air intake. The 130mm tb is 5 1/2 inches in diameter. The intake that comes with the 3.0 is 4 1/2. So I guess off to the drawing board
Become a HVAC tech??
Hatermkr
Hatermkr
West bend
2016 helldemon
Hatermkr
Hatermkr
West bend
2016 helldemon
Hay dudes,,, dude ettes, sorry Linder. You have an HVAC dick nition hea. If it ain't broke it will beez by da time I getter dun. No kidden, buttster I have been a union sheet meta, whatever metal, all my life. I do sea yall delima thow. If I were youz, I would call the dick weeds tat designed- built the contraption. They have seen tits befoe and have a fitten on the wall fer this. If not, they can make 1. Kinda hard ta do that from hea. 2 measurements and you will be a runnin. Wi con, no dirty air yet. Take it off till you get the fitting. Run bettah any way.
Tucke annotha look. Nuttin a rad ditea ator clamp and or screws and tape can't handle. Foil tape, don't cut yo'all self, will fix any thang. If palastic wit transituition into matal. Tape, 3 layers. Clamp and screws will break da plastic. Mon u factoring issue, call their shop and complain. I bought an intake fer my souped up COPA CUMAROE, had to rebuild the metal intake. 025 metal, 90, reducer, filteh, reducer annota filter, rain guard cause it went 5" above the pavement. Heat, weld, solder, tape tape and tape. 2 daze and wala fixter,, turd. Lucked bettah than factory. Watt eveh union piece of shit designed that crap, but da hole thang waz custom. Custome, modified, souped upster, well created,,, anothu woods, a F- ing nite mair to tha numal person at 1 am in da morn. I beah came a street enginah aftah redesigning shit that a 6 yeah 2- 8 yeah college dacree idiot deesigned dat dun not work. I ended upster redesigning systemd that it tuuck a normal persun and cent tam to college 2 take da common knoledge out of em and replace shit head descrap, $$$$$ lots, to turn them back ass wards. Makem cents, did me. I made millionsn of melons off toes idiots. Wait till a high rise was built, 1 year out of engineering waranty,, and promise to make it bettah bi 15% to da owner whore no charge. Waaa Laa. $$$ to die in an ALF wit.
Very curious on the choice of tape @Hatermkr
Cheapest tape is FSK foil scrim. Next I wood use is FSK reinforced FRK tape at $20 a roll compaired to $10 plain FSK very thin at Homo Depot. I would mastic and seal da joints for humidity issues here in Fl. I would bea happy to discuss tapes if youz wish. Foil Scrim Kraft, FSK, would be my choice, hea.
Hatermkr
Hatermkr
West bend
2016 helldemon
Holds together till you weld it
I was just joking around, I meant why scotch tape over masking tape or duct tape. Lol
Hatermkr
Hatermkr
West bend
2016 helldemon
That’s a hat was close
Weld it braze it tig it. You'll choice and machine youz have available. Me, I wood piss on it and by a different 1. Juast make em sure youz gots it grounded and sum vuant it lation on er so youz don't smutter you'll self.
Trackhawk, RS3, Golf R
Shit, I didnt even consider that fact. Dam now more custom fabbing smh good info thanx for posting totally forgot about that gonna tell the shop the fab guys gonna have to come there and make an intake. Maybe ill do it out of Titanium.
This is for my Trackhawk tho. Its gotta fit just perfect tho cause I got the Cortex expansion tank for more coolant which im gonna use to plum into my Interchiller stage II. It only works with the Legmaker intake due to the design so more money ill have to spend smh.
Hatermkr
Hatermkr
West bend
2016 helldemon
This is for my Trackhawk tho. It’s gotta fit just perfect tho cause I got the Cortex expansion tank for more coolant which im gonna use to plum into my Interchiller stage II. It only works with the Legmaker intake due to the design so more money ill have to spend smh.
Hopefully I can fire mine soon. At road America
Hate man....what's up with the sausage fingers..:unsure::giggle::giggle::giggle:;)...(said with all due respect and admiration..:p:p:p)
Them are "Wrenching fingers"..... :)
I think those are his friends Jeff’s hand🤣
Jeff is new to hellcats. Hasn’t wanted to void the warranty yet
WTF...wrenchin hands...it's a catchers mit...no way he gets into tight spots...
No turd, it is ware you'll live. Ass ov 2 day youz guys are gettin hit an extra tax fer sending you'll trash 2 NJ. Weeze just place ours on Carnival Cruise Shits and sent tim outster sea. Know tax there. Slumb ass Carn um val makes moe $$ off of dumping crap than ta dew off of personel fool side attention. Youz rednecks frum Alabamar, Georgiana, N Scaroliner, Lousitscanar, have you'll fun cause you'aals crap 2 see is fixin 2 stop. Out of Tampa x espicially. Drug snaffer dugs will buster youz asses.
