- St. George
- UT
- 2016 Dodge Challenger Hellcat
- HFCOTM
- View Images
If it was tightened down and then the transmission bolted to it you’re probably not going to see any rub marks on the nuts themselves, you’ll have to use a straight edge on the back of the block and check everything to be sure it’s all flush, the back of the block, the rear main seal, and the oil pan should all be flush
- 1
