FFBOS
FFBOS
Mount Prospect
2016 Hellcat Charger
Thread Starter #301
The 108 died?
That's no fun.
I'm hoping I have better luck.
Yea I confirmed with Nick Williams who makes them, they all run on stock motors, which is fine for the smaller blowers. How long they last behind this one is a different story.
Doesn't sound like very long. The NW102 on the V even had issues but they supposedly solved those.
I was hoping the hellcat wouldn't fall prey to the same.
Curt pointed me towards the Kong and I'll be on stock blower so...*fingers crossed*
FFBOS
FFBOS
Mount Prospect
Thread Starter #303
It will be fine there. The Maggie has enough suck to pull them shut under WOT. Mine did ok to 7200 until it didn’t lol.
Primetime Hellcat 17
Phoenix
2017 challenger Hellcat
The 108 died?
That's no fun.
The TB issues are becoming a joke for everyone. Going through the same process. I’m on my 3rd TB now. Let’s hope the Kong 108mm holds up.
FFBOS
FFBOS
Mount Prospect
Thread Starter #305
Time will tell. The 108 is built with stock guts.
FFBOS
FFBOS
Mount Prospect
Thread Starter #306
Got a little side project done today. Installed the Mighty Mouse catch can "wild" system. Did a test idle / parking lot drive of the 112mm, it drives, but needs a tweak for sure. Going to get a revision from Jeremy and then work towards WOT hits once the weather warms up a bit.
FFBOS
FFBOS
Mount Prospect
Thread Starter #307
Finally getting there with the 112. Been a bear to get exactly right. Got WOT dialed in, just have to smooth out a couple low rpm drive ability issues. Almost drives like stock.
Saw a 1psi gain and it makes peak boost much quicker than my 105/108.
FFBOS
FFBOS
Mount Prospect
Thread Starter #308
Also, changing up the look a bit. Not sure if it will add HP....
6EBEEB57-8595-435F-8437-EAD85651B82C.jpeg 00D120DC-193F-4F0A-B6C0-CE41F6212AA6.jpeg B73ABA77-1A68-40FE-B9AD-28C3350B79DE.jpeg
Is the change up a widebody kit?
The car looks amazing. Happy to see you’re making more boost sooner, that’s more valuable than the additional psi up top.
View attachment 40531 View attachment 40532 View attachment 40533
Definitely gonna want deets on this...especially since I curbed mine and it needs the fascia tended to anyways.
Looks GREAT!
I went with the 108 for the Jokerz blower. I drop the car off in a week exactly. Can't wait to see what it does...but I hope the 108 holds up longer term.
I don't think I'll regret not going 112 until I do a much larger blower...which isn't in the cards.
Dat widebody thang tho...
Car looks great.
WhipCat
In the Jungle
Looks phenomenal. Your right in the thick of it now.
I read the post on the loss of power after the port job.
Was wondering what the issues there are. The text from Tim seems like it could be it. What about a port job on the heads. And what are you running for exhaust? Maybe you need to open that engine up some more? Could help with the cam setup you have?
FFBOS
FFBOS
Mount Prospect
Thread Starter #314
Heads are the only restriction on the car. I also believe some of these other testers spin close to 7500rpm. Crazy.
I have catless after headers. All 3” to the back. AWE catback.
FFBOS
FFBOS
Mount Prospect
Thread Starter #315
Looks GREAT!
Nick Williams makes all the 108’s for these cars I found out. Should be ok.
I ran into a bit of a snafu with the top rear panels. My 315 is hitting the bracket on bigger bumps and dips. Popped the panel off. Need to clear it a bit.
Now I had to get on this forum at 3:22 am. Cold the cat says. Now I painted where the car is blue under the hood red, the Hemi black,, all red and black. Cat heads and back Dodge red with black louvers. Have to get EL Ri Cola to post. The cats head's willhave red eyes on em as soon as I find wht Fiancee #6 did with em in the garage. The 12 I will have the engine and cat's heads touched up. All satin black will be touched up, spoiler and hood. Really wanted that shacker hood. 2001 or 02. Mabe next. Painted engine,, again. Wait till the touch up o Co La from Indian Rocks Beachn the 12 th be ready on the 15 th. Have El Ri Co r Snake #2. OLa take pics at Quacker Snake and Gube on Thursday.
FFBOS
FFBOS
Mount Prospect
Thread Starter #318
Another potential issue. Killer Chiller stopped chilling the SC coolant. Still blows ice cold cabin ac, so it looks like a potential thermal expansion valve....
FFBOS
FFBOS
Mount Prospect
Thread Starter #319
Look is almost complete:
Also moving on from the killer chiller and doing a stage 2 FI system. Have to figure out how to make it “jive” with my current bumper tank.
C4F65D6F-0D1C-4B51-9B07-94D79D122C13.jpeg 1BF08815-4674-45D9-B1FD-0AD4B89753C0.jpeg DEE809A7-181B-41D6-8989-E30AD7245DAB.jpeg 74B0F0C9-71D1-4528-8200-40E5253D0B71.jpeg
I'm normally not a fan of the WB setup, but it looks great on your car.
