- Northern
- IL
- Rammer
We have been putting a ton of prep into the block. It’s a early (hard) 6.2 BGE. We’ve been opening up the water and oil passage ways and are smoothing and polishing every sharp or ragged edge. Particularly the oil returns. They’re even being polished to increase return and reduce oil suspension as the crankcase is breathing through those returns. The difference in these early blocks is evident when doing the porting. The newer BGE’s cut like butter compared to the 15-16 blocks. This thing is like kryptonite compared to the current blocks. We’ll be using a Callies billet crank, but the big deal will be the rods. They are special forged Manley I-beams that they produce “on occasion”. The magic of forging at its highest level. Adam tried to get some more but they said they are not making any more of those at this time. We are also hard filling the block to the water pump.
