Which TPMS sensors for Demon skinnies?
Saint Paul
Dodge SRT Demon
So you are saying you installed them wrong and they failed? Not sure how different the demon wheels are but I have them installed on my forgestar 18x6 and they fit fine
Like said they are not needed but it is nice not having the light on driving to and from the track. With the rears low at the track you still get the light there
Yes
Upside down or turned 180 degrees to get
them to fit.
They extended to far out passed the wheels
Edge or scrub line.
If they don’t fit correctly do not use them.
I just got rid of them all together front and rear.
I used the same valve stems that are in
The Demon crate
On all four wheels front runners
And rears. I do not trust that cylinder stem nut.
The light does not bother me I know why it’s
On.
Saint Paul
Dodge SRT Demon
This is not my first rodeo, I have driven on drag radials and skinnies before... thats not what I'm asking here. But for what it's worth, my car is NOT a daily driver. I just drive occasionally on nice days, it never sees rain, and I don't go corner carving as I've got a better car in my stable for that. It only has 700 miles on it in the past 6 months to give you an idea, and this rate will actually go down because the first 500 I was trying to get quickly for break in purposes.
I chose the MT Sportsman S/R 28x6 because it's a radial tire that is suited for street use. Look it up if you don't believe me. Ron Silva runs this as his everyday setup as well. Not only will this help me preserve my original wheels and tires for future collectability, the front skinnies will also help reduce the chances of rock chips from the front 315 drag radials picking everything up.
So if anyone has any helpful suggestions on TPMS sensors, please jump in.
4,200 miles
On Demon front runners
With bias ply tires
I’ve never driven the car with the
Rear tire mounted in front.
I installed factory Tpms inverted (Not a good idea)
The tpms sensor nut came loose after crossing...
You really can't blame the sensor for what appears to be an improperly installed valve stem. And it sure doesn't help if also installing the sensor wrong on the valve stem.
Valve stems for TPMS can be used as regular valve stems. Just unscrew the sensor, or don't install it on the valve stem in the first place.
Saint Paul
Dodge SRT Demon
F6990EE6-C172-4894-84A1-4B8420AF7750.jpeg 105B1820-91BE-40DE-AF16-06D4536E326B.jpeg 247F2D07-D3D8-4B3D-977C-F7EE5D64616B.jpeg
They look badass too!
Death Valley
Hornet
BoostedGTA
BoostedGTA
Greenville
SC
2021 Super Stock
