- Bradford
- PA
- 2018 Charger Hellcat
You can get adjustable end links. Mine are Carlyle. I have their 15” conversion with the billet spindle that requires a really short link. I haven’t measured it but it is REALLY short. Adjusted to fit, it doesn’t hit my AAD arm.
That also looks like their toe rod in the picture?
What we are seeing is the factory sway bar pulled so low with a shortened end link that at full compression it physically contacts the rear upper camber arm I believe it is (they're all "control arms" to me)...
I'd also imagine a billet spindle would change some mounting locations or angles for fitment and may not have this issue as a result.
Has your rear sway bar contacted the top of your upper camber/control arm?
