Quick Factory HC Charger Tire Question
SpecOps Veteran
Fayettevile
NC
2019 Hellcat Charger, 2021 Hellcat Durango
I read the posts below and did not find a solid answer. My question is will 305/40's fit all the way around on a factory HC Charger without wheels spacers and rubbing in the front? I'm getting ready to order tires and am receiving alot of conflicting information. I can delete this thread after I get an answer if it's duplicated from information below. Thanks for your time and assistance!
V/R
SpecOps
SpecOps Veteran
SpecOps Veteran
Fayettevile
NC
Thread Starter #2
Nothing?
I have seen they fit a Challenger but I don't know about a Charger .
Somebody may give you an answer be patient :)
Linda :)
Matt someone with an SRT
Newtown
Here’s my opinion... first off from what I understand and heard Chargers have more clearance than challengers (non widebody) out back. With the right offsets, yes it can fit. Some tires like nittos run a little smaller.. Michelin’s I think tend to run a little larger. One thing I will add.. I have 285s up front and 295 in back Ps4s.. in my opinion any larger than 285 up front will look stupid unless you have some trick offset. I’m at 15mm up front and 25mm out back.. my 285s up front stick out from the car a bit. If you have 305s up front it might look ridiculous. And it won’t help with traction just add more meat for your car to tram line more on street surfaces. I like my 295s on the rear but sure if you like 305s on the rear you can go for it... That’s my opinion!
Newtown
Btw I run 295/35 not sure about 40s.
