My 15" Conversion on my Charger Hellcat
slowboat.srt
Surrey
Finally finished the 15" conversion on my 2018 Charger Hellcat
I used the AAD shortened swaybar links and adjustable toe arms to make the process easier. I also used the dusterhoff 15" conversion kit. The only grinding I had to do was remove the old swaybar mounting location by grinding it off clean. The shortened AAD swaybar links mount to the toe arms now. I also used a 3mm spacer because of how close the wheel is to the toe arm.
This car has stock rear springs with BMR drag springs up front.
The way it should be done. 👍🏼
@vortecd
You've been saved by this car (if you know, you know)
