- TBD
- TN
- Sufficient for most applications
Marc,
I have been thinking about you coming east in the fall for the MSHS event. The weather should be good and your cat will run at least 2 or 3 tenths quicker. Regarding us lining up, it is a drivers race, you are quicker based on Kentucky, 8.90 versus 9.006 (on boost). I am not sure it is worth the time and money for the drive. When I towed with my Ram 1500 gas motor, 10 or 9 miles to gallon (pulling 8,000 pounds) and currently my 3500 gets 10 to 11 on diesel, pulling 13,000 pounds.
I think it is outrageous that you could run in the heavy weight class and be competitive in the 8.5 class (you should run below 8.70, probably below 8.60). Maybe that is worth the drive, money versus crazy accomplishments, I go back and forth on this, a part of me says, carpe diem, send it, you only live once, another part says, save the expense, put the money into the cat, hmmmm
1
