- In the Jungle
- FL
- 2017 Challenger Hellcat
Went to the track with Marc and his wife yesterday.
Marc went from his one house in west coast of florida to his other house in the keys to pick up his wife’s redeye so they could meet up with me at a rental we got the scoop on that same morning yesterday. Badass.
Anyways, I’ve been 100% work mode for the past couple months and since the other forum took a shit, I’ve been just working my balls off lately. So I wasn’t changing my drag tires at all. I was too whooped tired so I just showed up with my 20” vossens w/ MT street SS. My car was running my low boost setup daily street tune. I was running a full tank of pump E85 with 5 gallons of VP C85 mixed in.
Drove to the track and was immediately up on the line to make a pass.
Made like 6-7 hits. And was fully consistent 10.1x at 142.xxmph with a 1.77 60’.
My car was spot on consistent. I spun once trying to get the car to stick and get me a 9.99 but the track prep wasn’t crazy.
The observations on the FI interchiller are as so:
The ambient temperature was 88degrees with a DA of 3400. Allot of moisture in the air, it drizzled a little bit earlier in the rental.
The intake air temp was 98 degrees.
The S/C intercooler temp was 78 degrees
These temps are with a hot car at idle, I did not attempt to cool the car down during any passes other than opening the hood between passes with 2-3 of the runs back to back. My car stayed running quite a bit.
These temps are also with drag mode engaged. It did not matter whether the switch was 50/50 or 100 drag mode, the temps would not get any lower. In fact I noticed no real difference between the drag setting for the chiller.
I made a pass and monitored the intake air temp. When I was at the double yellow ready to launch we were at 98 degrees. When the pass ended it climbed to 127 degrees.
Which is really good for my car considering I was typically finishing around 160-205 degrees prior. My goal was 130 degrees or less. So we are doing nice right now.
This is the pretty neat obervation. The S/C intercooler temps were at 78 degrees at the start of the pass. At the end of the pass it stayed exactly the same 78 degrees! Can you believe that, not one degree more. I watched it the whole pass. The temp of fluid at the sensor right by the blower was reading 78 degrees. That 78 degree fluid stayed constant the entire pass. That’s pretty cool.
NOW...as I slowed down at the end of the pass I noticed the temperature start to increase. It started to go above 80, then as I made the u turn at the end of the strip to come back it kept climbing. It got to 93 degrees before it stopped, then started to come back down and work it’s way back to 78 degrees at idle in the pits.
Sooo. I think. The large 5 gallon reservoir in my trunk was holding enough 78 degree fluid that it had enough for the entire 1/4 mile pass and then enough for me to make the u turn at the end of the pass which takes me about 7-8 seconds, by the end of that time it only went up 5 degrees. After another 4-6 seconds it climbed another 10 degrees, which means it was finally out of chilled fluid.
So a 10 second pass plus 11-14 seconds after the run the temp only went to 93 degrees.
Let’s say 20 seconds of cold fluid delivery continuously. That is a serious pull. That means for my upcoming half mile I should be able to validate this and see. I can finish a half in 17-22 seconds depending on conditions. So it’s a perfect test, and it’s the max capacity I need.
After looking at the trunk area I think there is room for improvement, I need to insulate the ice tank, I bet I can get the net temps down another 8-10 degrees. That will boost all the stats I explained above. From IAT to intercooler temp.
First time out since the new round of mods and the new transmission as well. I was mostly just having fun and testing the chiller.
3
