Harmon Kardon Sound system on the Hellcat
HellcatMike
The Harman Kardon 900-watt 18-speaker system on the Challenger Hellcat.
dmac799
I purchased the Harman Kardon upgrade too. However, I do not have the speaker that you are showing in the picture. I have a blank space where a spare tire should go. Now I am wondering if I did not receive what I paid for. Is this how you car came delivered from the factory?
RonHellcat
Did you get the Harmon Kardon Audio Group $1995 upgrade? If yes then you should have the subs in the back.
dmac799
As you can see in the attached pic, I do not have the sub like you have. Yet, I paid for the $2000 HK upgrade and it shows on my sticker. And it even has the HK label on the inside of the door near the sideview mirror. Something is definitely wrong.
As it stands now, I have to crank the volume to the max to hear anything, especially with the windows open. So if this is what the HK sounds like, I want my $2000 back. For that amount of money, I could have upgraded the components myself and had a much better sound.
LonestarHellcat
I was told by my salesman that there are no spare tire sub box on the Charger, just the Challenger. The subs are located behind the rear seat on the Charger.
RonHellcat
Like Lonestar posted the subs are behind the rear seat. Either way the HK sound system on the Charger is horrible compared to my old M3.
dmac799
Thanks for the insight fellas. I will take a look to see if I can find all 19 speakers just to make sure I received the HK system. Assuming so, that brings me back to my original issue of expectation versus reality. I certainly was expecting better.
Meanwhile, I called SRT and they are definitely working on an update for the HK audio system. Evidently they have been barraged with owners complaining about the sound quality and its loudness. So at least I know I am not the only one out there. Now we just have to hope the fix cures the problem AND happens this century!
LonestarHellcat
I'm glad Dodge is addressing the problem. Would be interesting to hear how they plan to resolve it. Maybe larger subs lol?
rfinglet
Thay still have not addressed the issue. My new 2016 hellcat charger has crappie sound. Very disappointed in the $2000 add on. All bass. No mids or highs.
Sent from my SM-G935V using Tapatalk
SpecOps Veteran
Fayettevile
NC
2019 Hellcat Charger, 2021 Hellcat Durango
I too am unhappy with the sound. However, all it needs to release the full potential is the AP4 module and my JL amp I used on my factory Scat Alpine speakers. You would be amazed at how well they sound when powered correctly, I can only imagine what the HK will sound like amped up.
SpecOps Veteran
Fayettevile
NC
Just got my hellcat back from the stereo shop. The HK 19 speakers count pairs in the door. So for example, the 6" midrange WITH a tweeter counts as 2, and so on and so forth. I disconnected the lackluster factory amp and put a JL audio 6ch amp. That REALLY woke up the system, as in will make your ears bleed if you want it too.
Skrelnik
Fairfield
By any chance did you happen to see what the speaker's specs were, like ohm, watts or even are any dvc vs svc? Also, are all speakers amplified from the amplifier, and how many channels are coming out if?
I would love to wake up this system...
Decay
Astoria
OR
2019 widebody Redeye
Can you run that amp via the factory head or is there a seperate remote for this amp?
I got the 18 speaker 900 watt with the sub woofers in the bottom of the so called trunk. It does take up all the space where the flat tire pump comes in instead of a spare tire. My buddy has a 2019 red eye and it does not come with the woofer system. He was amazed to see this in the rear end of this H/C. I did test drive a new red eye 2 weeks ago and standard, he said, comes with a 19 speaker and the woofer system. It is amazing and I am a pro Bose purchaser, but very impressed with this system. It has broken a window in the process of figuring it out.
2025 Dodge Durango R/T Plus
Love the HK in my 2016 Charger. No complaints!
Me either and 1st HK system ever owned in a car, garage most important, and or house. Sounds great. No need for improvements at this point.
Skrelnik
Fairfield
I need more, especially an amplifier where I can utilize a Bluetooth chip that has better compression, such as an Audiotec Fischer amp with Bluetooth module.
SpecOps Veteran
Fayettevile
NC
ill ask the installer the answer to all those questions. All speakers ARE amplified from factory but underpowered. I did have to go from a 4ch to a 6ch amp and left factory sub unhooked because I’ve got a JL W6 12” sub that pounds.
Av8ing1
San Marcos
2019 Charger Hellcat
I'd like more details on the Amp replacement as I'm underwhelmed by the HK system in my Charger. The car is new to me so I'm still playing with settings, maybe I'm missing something but so far, it just doesn't seem all that great. Sort of like, I don't need 707HP most of the time but when I want it, I want it. I don't need rock concert volume most of the time but when I want it, this car doesn't have it. I'm not an audiophile and I realize an automobile is a challenging environment for quality sound but this, should be better, especially for what the HK option cost. So far I'm still quite happy to listen to the soundtrack the power plant provides but eventually I think more audio would be nice. I like the simplicity of just adding more amp if that provides a decent improvement and is not a huge challenge to do. I feel like the system stock is 5/10 and I'd be happy with a not crazy expensive upgrade to get to 7 or 8/10. However, with the modern cars having so much integration with various systems, I'm not willing to give up anything or jump through crazy hoops with aftermarket equipment to get it all to work. Importance of audio is < the fun factor of this beast, but more would be good.
SpecOps Veteran
Fayettevile
NC
All I put in mine was an AP4 module which you have to have and a JL audio 6 ch amp. It will blow your mind how good it sounds.
