- Murfreesboro
- TN
- 2016 Hellcat Go Man Go
Got to work on Go Man Go's fuel system this week. I had noticed the fuel pump duty cycle maxing out and fuel pressure dropping in upper RPMs so I knew the fuel system was at its limits. This occurred a bit on the Hellcat motor, but not near as much as it does now with the Redeye motor in the car.
Reminder I have the 2.72 Hellraiser pulley and run 93 octane. I see about 16.5psi of boost in warm air and 17.5 in good air like 50 degrees or better and have a Redeye engine in the car. Super easy install and is 99% plug and play as advertised. The 1% is having to move the fuel sending unit over from the original fuel bucket to the dual pump hat. Two wires easy peasy.
- 7
