Garage Door Insulation
I don't care how beautiful...or even if the streets are paved with gold...I'm not livin in triple digit heat...not even for one day...:eek:
but it's a dry heat :ROFLMAO::ROFLMAO:
So is an oven...and I'm not stickin my head in there either...cold doesn't bother me..over 85..(anywhere)...I melt like a candle...
Yep.....I hear ya.
Xylander
Tallahassee
My garage is also insulated with a full attic. The door is a very thick insulated door. I'm not sure what brand it is, as it was in place when I bought the house. All I know is that it's about 3/4" thick and is almost too heavy to raise by myself should the automatic fail. Maybe not so bad if I grease the tracks ;) The owner who had the garage built sourced all the materials from Home Depot... so it is something you can order.
Not every day you see Thomas the Tank Engine as a hydrogen bomb
should've had George Carlin riding it down like Major Kong :p
2025 Dodge Durango R/T Plus
I have insulated garage doors, insulated ceiling and insulated attic steps but I don’t believe that helps much to keep the garage cool because it still gets hot as hell in there. Warm air rises. You could leave the access door to your garage attic proped open or cut a hole in it and cover it with a screen to let some hot air go up. I guess it should exit thru the ridge vents or gable ends? I have a solar powered attic exhaust fan in the roof to try to get the air flowing from my soffits thru the roof. I think I will have a Mitsubishi heat pump/dehumidifier installed. It costs about $6K.
