Build progress
Thread Starter #142
Better. Not by much, but better
Thread Starter #144
It’s fine. If it hits I’ll put poly mounts in it
Called HHP. Said they’re only ever to get 1/4” and some are real tight. When it is, they bash the ribs flat. Not possible for me with the engine and cradle in the car, and the engine can’t be shifted over.
Ribs on the chassis?
Would it have been easier to drop the cradle with the engine and put the headers on then put the cradle back in vs all you went through?
Thread Starter #147
Yeah, problem is you need a lift for that
Thread Starter #149
Better desensitize those knock sensors. 😂
Thread Starter #152
I have enough room I think. How much room do you have in yours?
Stock exhaust. Plenty of room.
Thread Starter #154
No headers? Thought you had them, must have been thinking if the race car
Correct have 1 7/8 headers on racecar. Plenty of room
Do what he says Holy guy....:oops::rolleyes:
Thread Starter #157
Like I said, if they cause issues I’ll put poly motor mounts in and see if I can shift the cradle a bit
Sounds like you like workin on it...more than drivin it
Thread Starter #159
1 & 3. Will have to check to see what the gap is when I’m finished.
FYI the online Chilton manual says in order to replace the exhaust headers to pull the heads off. Would cost you a head gasket and an intake gasket, but time-wise might actually be quicker. Probably much less frustrating for sure--might also make dealing with clearance issues easier. The downside is how many more mating surfaces you'd have to clean... which is arguably the suckiest part.
