Boost Gauge
Plant City
2019 Challenger
I just noticed that my boost gauge, built into the SRT Pages, doesn't progress smoothly through the numbers like it used to. When I go into boost it will progress properly to around 6 psi then as I continue with throttle it wont show any additional numbers, just sticks at 6 psi, until I go WOT then it will shoot up to 16 psi. It used to go through the numbers numerically smoothly, but it is acting strange now. Not sure if it is something to do with the most current UConnect update or something else. I just cleaned my MAF sensor in my JLT intake thinking that may have something to do with it, but it is still doing it. Any idea? Thanks.
Disconnect thebattery and hook the cables together and do a hard reset see if it helps , other then that the map sensors are how it reads boost
bc_hellcat
Plant City
2019 Challenger
I wonder if I have a faulty MAF sensor. Would there be any other indicators? Because the car runs fine...no issues.
Boost is read by the map sensors not the maf
