Anyone have access to wiring info?
I'm looking for the wiring colors and pinout details for the FPDM (fuel pump delivery module or fuel pump control module) connector on a 2016 Hellcat (or similar). Anybody got access to Tech Authority and can grab it for me?
It'd look something like this, and have a picture of the actual plug with numbers on the pins and what they go to like power ground etc.
Subscribed
jgilj
Walland
21 Challenger Super Stock
@DRAGRCR probably will know.
DRAGRCR
VICTORVILLE
MANGO D170
I only go on Tech Athority as needed. But they changed the web site and now it's impossible to download and save stuff. I could not figure out a workaround beyond screen shots. It sucks. I saved a lot of stuff for 2020 RedEye when I could but it would not apply to a 16 Hellcat because if One PP VS 2 PPs. A lot of stuff will work on all years or be very similar. But this is not likely.....
Is this of any value? this is in the Charger electrical diagnostics manual ...
@HWDan super helpful. Thanks for providing this info. I'm trying to determine which pin on the FPDM connector correlates to the fuel pump relay. Looks like pin "A".
At some point soon we are going to look mine over why it works. Fuel pressure had a slight drop here and there today but not like before so it is working. Last time was dropping into the 60s and getting into 80% duty cycle. Today never below 72 psi (75 commanded) and one time injectors were in mid 70's for a gear
I uploaded FSM's with wiring data.
Look in the wiki.
Just snagged it. Gonna be a rainy day here tomorrow so I have a project to work on. Thanks a TON!
@HWDan is this in the documents you posted? I can't find it and was hoping the pages before or after may help me. I see a couple things different than mine for example Fuse 26 in the diagram says 25A but if that's indicating the fuel pump fuse that's Fuse 21 in mine and it's a 30A.
I'm also puzzled by the description on PIN A of the FPCM (the dark blue and orange wire) indicating an OUTPUT when it's obviously being fed by the fuel pump relay making it an INPUT?
Chuck
Auburn
2021 Redeye Super Stock
I Have 2015 Challenger Tech Authority wiring
Can you post or send some images of the FPCM info like above?
From 2016 connector database:
Maybe there is a difference in the Charger here?
I trust that now @Chuck and @Diboblo can pinpoint exactly what you need to see.
(although even Diboblo's PIN diagram shows A dark blue/orange as the output unless the terminology is reversed depending on perspective)
Chuck
Auburn
is that what you need
Thread Starter #20
That's lining up with other diagrams so I think that's what I needed. Thanks for the help all.
