- St. George
- UT
- 2016 Dodge Challenger Hellcat
- HFCOTM
- View Images
Just for the sake of discussion.... I have a commercial pilots license. Not currently working as one, but have a fair amount of time flying coast to coast on autopilot. One of the things that pilots are periodically checking and resetting is the altimeter. That tells you how high you are above SL and that setting is given by air traffic control stations all over the country. It will change over distance and changing weather/temps. It’s actually a pretty critical setting because airplanes fly at assigned altitudes depending on whether they are going east or west. You don’t want to fly head on into someone going the other direction because your altimeter wasn’t right. So that info is given every time you make contact with a controller. I have to assume that these apps are getting their DA info from these stations and there can’t be variances of a thousand ft at the same place. Maybe I’m wrong and that’s not where or how these apps are getting their info but if they are.... I would trust them over a handheld.
- 2
