New drag car from dodge
dude that’s a promod.
At that speed, they all have to be.
Even the Larry Larson S10 changed just about every body panel etc before making a run on drag week to set a record and make a point.
You need a 25.X cage just to run under 8.50s. Do you need to run faster than that for a street car? And even those cages are only good to 7.50!
WhipCat
In the Jungle
im not sure your point.
all I’m saying is the S/S isn’t going to go any faster. Maybe launch will be slightly better. Buts the car is maxed out. I’m hoping this is the last iteration and we got a new platform to play with.
Dodge is kind of at the limit right now.
NHRA won't let them built a 9 second car to race from the factory. Unless you want a corner carving car, in which case, that is long over due
