Hellcat Charger stock 10.99
Made it to the track last night. Picked my Hellcat 4 weeks and the track finally opened. Car is stock expect drag pack and rear diff brace. Had under 1/2 tank and didn't take my 20 lbs tool bag out (forgot) Scale was not working so no weight I bought some M&H 275/50/17 last year for the Daytona. They only make a 9" and 11" wide tire in a 28" 17 and I'm using a 10" wide wheel so I went with the 9". DA looked to be around 1500 so I was thinking 11.2's based on others with Chargers. Not knowing what to expect I eased into it with a 1.62 60ft and ran 11.00@124.97! I could have went home at that point since it went faster then I expected. Next pass I got into it harder spinning through 1st and ran 11.43@125. One of my goals was to test stock air filter against the Green filter so I changed it out. Next pass again spun to a 11.53@123.97.At this point I was more concerned about hooking and rain was coming. I did my best John Force impression and filled the area full of smoke almost to the starting line. I knew right away I left some on the table by they way it left but it wasn't spinning so off we went. I was handed the slip...10.99@126.40 with only a 1.64 60ft, we did it! Not 5 minutes later the rain came and ended the night by being after 8 they were not going to dry the track. They have a test and tune today and the DA looks better but going to get the spacer under the blower on
My air filter test wasn't the best I could have done. I really need to be able to switch back and forth. I did run the same lane every pass. DA was very close for both passes. The data I have, The Green filter ran 100.63 at the 1/8th to 100.22 for the stock filter. The Green filter had better mph with a 117.42 at the 1000ft to the stock filter 115.43 and 1/4 mile 126.40 to 124.97.
I need to get some better test data though
tkracing1
Bay Area
2017 challenger
My air filter test was wasn't the best I could have done. I really need to be able to switch back and forth. I did run the same lane every pass. DA was very close for both passes. The data I have, The Green filter ran 100.63 at the 1/8th to 100.22 for the stock filter. The Green filter had better improvement with a 117.42 at the 1000ft to the stock filter 115.43 and 1/4 mile 126.40 to 124.97.
View attachment 18603 View attachment 18604 View attachment 18605
Nice pass... congrats. Car looks badass!
72 440 Barracuda
Graham
2015 Challenger Hellcat
I would be very happy with those numbers - Congratulations, youre in the 10's !!!! Very well done!
Pretty awesome for first time the car has ever been run! Way to go![thumb]
Nice job!
Thanks everyone. Pretty happy with the times. Hope to get some better testing with the intakes and the JLT. I have an easy 50 lbs I can get out of the car maybe a little more. It will go 10.8's maybe 10.7's
My first time out I was in the 10.9x club too. Good numbers and great looking Charger!
Beast707
Carol Stream
2018 Challenger WB M6 Hellcat
Getting it done! Kickass man!
Great time OP. You close to the track? Drive on the DRs every day?
25 minutes. I put the tires on and drive to the track. Have some Nitto 555rII going on for daily driving
WTG , Congrats on 10's , nice passes !
BTW , fastest color & like the stripes. ;)
Way to represent! Car look and obviously runs awesome!!! :)
YMMV
Morris Co
18 Charger HC
Congrats! Love seeing fast chargers!
The Max
Toms River
Sounds like a fantastic day at the Track!
Congrats on the great pass down the track and I think the car even has a better time in better conditions waiting for you.
