Best Oil for Non High Performance Daily Drivers
This stuff is amazing and no other oil cleans like this. Wear properties are great, too. The Oil Geek is a degreed tribologist. Many accounts on BITOG of it stopping oil burning on high mileage vehicles.
4oz of Swan dish soap works wonders for stuck rings...(been using it for years):p;)
Been using it in my Jeep and the Challenger. Valvoline has been my other oil I have used for many years so when this came out switched to it
I’ve been a Mobil 1 guy for decades now. I run it in all my ice’s. Haven’t had a reason to switch just yet, but above looks good.
Started using it my Grand Cherokees.
i’ve been using Valvoline full synthetic in all my vehicles for 30+ years now. every forerunner I’ve had had over 300,000 miles on it and it failed because of frame rot not engine or drive train issues. All Looked brand new inside. I use Valvoline restore and protect in everything now since it came out.
This is my previous 4Runner when I did head gaskets on it. It had just under 300,000 miles on it. It saw mostly highway mileage at high speed and a lot of WOT driving, it had no carbon in it at all lol it was this clean upon tearing it down, intake valves, piston crowns, cylinder chambers. Look at the cross hatching in the cylinders, like the day it was honed after 300k miles. This ran on Valvoline 10-30 Max Life Full Synthetic its whole life. Restore and Protect is even better now!
IMG_6581.jpeg IMG_6572.jpeg IMG_6542.jpeg IMG_6548.jpeg IMG_6540.jpeg IMG_6536.jpeg IMG_6543.jpeg IMG_6545.jpeg IMG_6557.jpeg IMG_6550.jpeg IMG_6541.jpeg IMG_6538.jpeg IMG_3567.jpeg IMG_3570.jpeg
Really. Heard trans fluid in the engine does the same thing.
View attachment 178860 View attachment 178861 View attachment 178862 View attachment 178863 View attachment 178864 View attachment 178865 View attachment 178866 View attachment 178867 View attachment 178868 View attachment 178869 View attachment 178870 View attachment 178871 View attachment 178872 View attachment 178873
Cleanest engine apart I've seen nice work
My friends dad did that one time back in the 80s. There was so much smoke someone called the fire department thinking there was a fire:LOL:
Interesting to hear Valvoline recommended. Years back it was accused of sludge.
I use Penzoil Full Synthetc in all of ours. Used to use Penzoil Platinum but testing showed full synthetic was as good or better and like $22 for 5qt at Wally World. 4runner is at 170k miles and climbing.
Wow, what did you usually run for fuel?
High tier Pump 87 but I use Royal Purple max clean injector cleaner at double strength every 3rd or 4th tank as using it always gave me three or four MPG more when it was in the tank I don’t know why, but it’ll always did
Valvoline Restore and Protect we clean up those engine internals in three or four cycles. You’ll notice on drain your oil will be a reddish color and when that reddish color disappears, your engine is clean inside. For the first run of it don’t go above 2500 or 3000 miles or change the filter during the interval because if you cut the filter open, you will find a lot of sludge in it most likely. The stuff really works. I’ve seen videos where they’ve run engines constantly for months, and tore them down and tested them to test and perfect restore and protect, first formulations were actually too aggressive, and they tamed it down some because of the filter clogging issues in really dirty engines.
