Depends on what you are working on
Of course, but I usually need to pull it due to what I'm working on
OK Un Holy Guy....I threw the gauntlet down to Bull and you...let see some "REAL" facial pics of you and Bull.....c'mon dont be a pussy
uhhh...where's the melon:unsure:
Now it's yer turn pencil protecror boi...WHERE"S YER PIC
I don't know how to post pictures
You are trying my patience...:mad:
It's my guess you underestimate my resourcefulness.....do I need to garner said photo's on my own...(careful before you answer););)
Yes, it does. If working on the brakes on the left side, disconnect the negative. When working on the right side, disconnect the positive cable.
22RENBS2 & 170
Roads are dry, mid/high 40’s today. Might try and take the cat for a walk.
You should see my driveway! If you take a ride, feel free to come visit! :ROFLMAO:
22RENBS2 & 170
Changed the oil in the 170, still haven't driven it other than on and off the trailer. Filled the diff, it needed a lot, maybe 8-12oz. Cleaned the exterior and covered it.
Need help: The black hood, roof and decklid are way harder to clean than the paint, the vinyl? wrap seems to have absorbed oils and whatever from human paw prints all over it from sitting in a showroom for 2 years.
They cleaned up ok with Meguiars Detailer, but if I spray more detailer on it they re-appear, but when it is polished and dries the fingerprints disappear.
It seems the wrap absorbed the oils/contaminates. Is there some kind of treatment for the wraps? Like armor-all? That will be absorbed and displace the contaminates?
Welcome to my world. The only FCA/Stellantis vehicles I haven't found low fluid levels in are a '23 and a '26 Durango.
There's a reason (okay, several) I trailer the vehicles home, then put them on the lift to check fluid levels. And install magnetic level plugs. That's standard procedure before beginning the painful break-in, primarily for the diff gears.
