triple pump fuel system
Ridgeland
SC
2016 hellcat A8 and 2016 M6
How or where would be the best place to buy a triple pump system I dont want to add a return line. And does anywhere give instructions any more....that would be nice have also. I get tried of carry my car somewhere else to be worked on!!!! I want to put the system on myself I may be old but I still know how to turn a wrench. I have worked on most my cars although the cars now and so much crap on them you need a little help (Instructions) Any suggestions? They always say plug and play really!!!!!
Tapped hands down, plug and play
Contact Rick at Tapped Performance. His systems wiring wise are true plug and play and he has instructions with pictures to guide you through installation. It’s not that hard to do. Most difficult part is getting the fuel line unhooked from the stock pump and getting it out and new setup back in with our F ing up the fuel level pickup float and potentiometer.
Or OST dyno, they have a nice mount for the 2nd/3rd FPCM
The trick for getting the fuel line in the tank on the stock pump undone is push the entire hose/fitting TOWARDS THE PUMP FIRST while holding the pump still with your other hand, put some force into it. Then squeeze the clip and pull it off
Like push it on more, then while pushing forward squeeze the clip and pull it off
Must be a pain with 3 pumps trying to get that whole assembly back in.
How much they going for now?
I'll recommend https://highhorseperformance.com/dodge/challenger/srt-hellcat-demon-redeye-super-stock/, here is their website page, if you have any questions, you can give Sales a Call @ 1-888-894-1115
Fore Innovations 97-134 L4 Triple Pump Fuel System for 18-23 Demon, Challenger, Charger SRT Hellcat Redeye, Jailbreak & Super Stock 6.2L H.O. HEMI
Description
Return fuel system capable of 1200+ rwhp with dual fuel pumps. (recommend to run one pump full time, then activate secondary pumps under load) Fuel rails in parallel with regulator after rails. Includes in-tank supply system that retains OE transfer, fuel level senders, and EVAP functionality, upgraded feed and return lines, y-block, high capacity filtration and F2i regulator with boost reference.
Fuel system becomes E85 capable by choosing F90000267, F90000274, F90000285 fuel pumps AND microglass SSD or stainless filtration.
Includes:
  • Demon/Redeye Triple Pump Module
  • FCV Checkvalve
  • F2i Fuel Pressure Regulator
  • 88mm Inline Fuel Filter
  • Compact billet y-block
  • Billet Hellcat Hemi Fuel Rails
  • Hellcat OE Feed Line Blockoff Cap
  • Fittings to use OE fuel pressure sensor
  • All fittings, hose, hardware required for typical fuel line plumbing
-40 feet of fuel line and 16 hose ends (your choice of type)
-Qty 6, billet low profile 90 degree o-ring fittings
-Qty 8, straight AN to ORB fittings
-Qty 2, billet low profile 180 degree o-ring fittings
-Qty 1, 1.25" o-ring port extension
-Qty 1, 2.0" o-ring port extension
-Qty 10, hose straps and mounting screws
Choosing Line Size: Choose -8 feed and return for dual pumps systems. We recommend -10 feed / -8 return for triple pump systems.
  • We suggest -8 feed and return in any dual pump setup, simply because there is no measurable benefit to running a -10 feed with any dual pump fuel system. However, selecting a -10 feed is a good choice if you're planning to possibly upgrade to a triple pump system later (via our triple pump upgrade program). Of course, it is possible to run a -8 feed and -6 return; however, most of our customers find the fuel system installation is more flexible when all the fittings are the same size.
  • We suggest -10 feed and -8 return lines allow any triple pump system to operate without restriction. However, -8 feed/return may be used if you're running three small fuel pumps (i.e. GSS342) or if your fuel system choice was marginal over whether to choose a dual or triple setup. So, if you're making 1100 rwhp on E85 (which is possible on a dual pump setup if your build is very efficient) but you chose to go with a triple pump setup, we would suggest a -8 feed/return since you don't need every ounce of performance out of a triple pump setup.
Choosing Fuel Line Type: FlexLP vs PTFE vs Startlite
Startlite will emit fuel smell and should only be used on cars kept outside or in detached garages/shops. Cars kept in attached garages should use FlexLP or PTFE, which will not emit a fuel smell. PTFE has a stainless outer reinforcement and will last forever, whereas FlexLP has a soft black/gray nylon outer braid and some insulating properties. (no NVH and more friendly with fuel pressure sensors/gauges). Our preference is FlexLP since it is much easier to work with as compared to PTFE which is not flexible.
  • FlexLP has the best ratio of pros vs cons than our other hose offerings. Most importantly, it's low permeability prevents fuel vapor smell when the vehicle is parked in closed areas. Cosmetically, some of our customers prefer the black outer braid over the stainless braid of PTFE.
  • PTFE is the most resilient to heat and chemicals than any other fuel line we offer, and likewise can be expected to outlast the vehicle. The PTFE core cannot be permeated by any fuel, and therefore will not emit a fuel smell when the vehicle is parked in closed areas. Cosmetically, some of our customers prefer the look (or contrast) of the stainless outer braid.
  • Startlite is race hose, and therefore we only recommend it for vehicles that are stored outside or kept in a detached garage or shop. Fuel can permeate the lines and will usually emit a fuel smell in the storage area.
CONTACT HHP FOR MORE INFORMATION OR FOR HELP IN SELECTING THE BEST FUEL SYSTEM FOR YOUR HEMI
This fuel system generates substantially more heat and capacity than the original fuel system. The high-powered fuel pumps make much more heat than the factory pump and the composite fuel tank construction acts as an insulator and stores heat. Additionally, the shape of the factory fuel tank limits the pickup capacity of this fuel system. The user (driver) must keep more fuel (than normal) in the tank at all times to minimize heat damage and ensure adequate fuel pickup.
It’s not that bad, just try and have tank 1/4 or below to cut down o the mess. Getting 2 hands in there to put the level sensor float back on is hardest if you have large hands.
Price? HHP configured with 2 295’s and a 285 as pump 3 with FPCM’s and a hobs switch for pump 3 and filter, see below.
rookerrobert
Ridgeland
SC
yep I agree looks like tapped performance is the way to go. Thanks
I upgraded my 2 pumps to 3 last summer. 3rd pump is on a hobs switch. Had to run wiring to engine for the 3rd pump. Tapped kit
rookerrobert
Ridgeland
SC
thats what I would like to do just get an adapter and place on the supercharger where the map is and run a vacuum line to it.
rookerrobert
Ridgeland
SC
I'm going with triple pumps right now I'm running dual 525's but I'm having an issue with them. I drain the fuel out last weekend and put in 15gals of c-85.....and now when you switch it on you can hear the pump's pressure up.....but when you shut it down on the passenger side you can hear sounds like a air leak and if you dont unhook the battery it will kill it over night. I changed the relay and had a xtra fpcm and thought that was it but it's not. When I drain the fuel I may have pulled something loose I'll know sat. when I can work on it.But it's just a strange sounds almost a tire losing air. If you can one of the fpcm lose the sounds stop's. after looking at this you can why I'm putting triple pumps in myself. I bought the dual pumps from steve white auto part...but didnt have time to install myself. But I cant understand why the green wire is patched thru to both fpcm?
rookerrobert
Ridgeland
SC
I put the 1/2 Fore rails on a couple weeks ago and had to extend some wire to the pressure switch the switch before was on the cross over pipe now it's back the back of the rails drivers side
I did Tapped dual then sent off for triple upgrade. Worked great. Videos of install on my yt channel
rookerrobert
Ridgeland
SC
ok thats great I'll check it out.....I'm just tired of not having enough fuel being pumps or injectors.
Tapped Performance is a Great company, and no different than HHP for lead times, because for 1 thing they both use Fore innovations.
Typically, these Fuel systems are not kept in stock because just as in HHP's
Description
Part of HHP Description for the Triple Fuel systems is based upon each customer's build. So, keeping stock doesn't happen.
This is from Tapped Performance's website
*NOTE: Current Order lead time is 6-8 weeks.
If you have a Demon or Redeye please navigate to the respective section for the correct fuel system!
Now, if you want to read about why Fore is experiencing problems.
https://justin-fore.com/
Tapped Performance has been working on some R&D parts for a while and HHP is waiting to T&T for them. ;)😎
~ Linda
View attachment 168304 View attachment 168305
Wow 4k is pricey
$3375.00 cost includes a triple pump whole kit. along with supporting parts.
Many, times people see prices for the single part and don't realize about the supporting parts that do need to go along with the modifications. @rookerrobert has already posted he has installed other parts and uses C-85. <----- A very Nice VP racing fuel.
When you have the need for higher HP of course it's going to get expensive, and you want what is needed.
As I posted, Tapped Performance is a Great Company. I post HHP's information because where someone purchase the products there or not, the knowledge is great. Which comes from an Experienced Performance shop Owner/Tuner who has been supporting the R&D and T&T since the start of Hellcat modifications along with the R+D and T+T of parts and Tuning.
I know Curt Dusterhoff from the track, he was first out withe E-85 Flex Tunes. I've seen several Hellcats at the Track running his Build and Tunes. Maybe from his website there will also be good information. Curt is another knowledgeable and experienced Tuner who is also at the track supporting his customers. Performance Parts | Shop Performance Auto Parts for Jeep, Dodge, Ram & Chrysler - Dusterhoff Racing
Also, BTW Curt does remote Tuning too!
~Linda
Pics?
