How much wheel HP does our Street Hellcat make on our Dyno?
stonewall
Conway
AR
2017 Dodge Hellcat Challenger
It must have blown up.
23 Challenger Demon 170
Under-Pressure
Space Coast
Stellantis 2dr
Some of these estimated hp #’s surprise me for a pro built & tuned, Thitek headed 426”. What am I missing?
Said mustang dyno so will be lower
Maybe I read it wrong but thought this is the tired shortblock dyno before switching to new engine?
Under-Pressure
Space Coast
Stellantis 2dr
426 before header test is how I understand it.
I was close
U tube video 965 with headers
How much did it make before?
Went from 931 to 972 or something. 40whp gain at the same ECT. More surprising to me was the huge difference between 150* and 170*… it was enough to nullify the headers on the first hit.
So it made more with headers or no?
That’s a pretty good gain
Did they retune it for the headers?
What I’m hearing is I didn’t waste money on agony. Nice
Expensive 40 whp though
Does that car even weigh 4000 lb?
Here is what I have seen with headers. Just installing headers is about a 0 gain. Why, because the gain in power is lost by less boost. So you make the same hp with less boost
What I also have seen when going to bigger free flowing engine the same happens, you can make the same or a little more hp but will also being making less boost
Boost is a restriction of flow but the more boost you have the more power the engine makes. Superchargers are limited on how fast you can spin them so when making the engine flow more adding compression is one way to add boost why this 426 has 11.5 compression
