- Clementon
- NJ
- 2018 Charger
My input on an idling engine (a performance engine you care about) is to not let it idle at a steady RPM, but to vary the engine RPM up and down.
The idea is to not let those rings wear in at idle which can create a "land" that the rings have to bust through once they get into the upper RPM range and everything stretches out.
When I'm warming up an engine, after about 1min or so, I'll start gently varying RPM up through 3000ish, no hard rule, just not set at one RPM.
And I always try to hit max RPM at least once when I'm driving, keeping that land from being created on the non-stretched side of life.
.02
.02
