Swapped Challenger Red Eye tips out for Trackhawk tips
Reputed to be a straight swap out, it was, after we had broken the OEM tips off the end of the pipes with a punch (I think the material and exhaust impurities had essentially "set up" into a kind of cement). Also noticed that from the factory the passenger side exhaust system was lower than the driver's side, by a noticeable amount (QC fail). Still need to play with the placement a little but haven't had time to get to it yet. Overall, I like them much better than the OEM. And, yes, the car is a dirty nasty pit right now.
1000020840.jpg 1000020839 clean.jpg 20241205_143355 clean.jpg 20240915_140349.jpg
Looks good! Do you have the longer tube on the outside and shorter one on the inside?
T
View attachment 151067 View attachment 151068 View attachment 151069 View attachment 151070
They do look good...but I dont mind the stock set up...(@ least not enough to make the swap)...
The opposite. Longer on the inside, shorter tucked in on the outside.
