Diablo Sport Suspension Controller
catdad
Lake City
#41
@Unholy707 front is 10% stock, I have his redeye at 8%
@Demid22 Ill buy a new cable and retry. Thanks for the heads up on win10
Demid22
Nurse
JONESBOROUGH
2017 Dodge Challenger Hellcat
#42
I had to update drivers and then make sure its using the correct port and baud rate. And even then sometimes i have to.unplug and.replug from lap top. But it does work.
Ive been playing with rear suspension dampening and acutally after so much travel(10mm?) Putting a full stop on compression in rear. Seems to be working nicely. Also loosening up the front end so the struts arent slowing the front lift down helps. However I think i have it set too loose as vianmy gopro footage im getting max lift and actually starting to come back down before i pass the tree. So i think.i need to slow the front down just a touch. But i guess i should just stick to my videos and such. Lmao.
Demid22
Nurse
JONESBOROUGH
#43
Did you edit it across the entire launch table or just the start?
Thread Starter #44
I’d expect way more than a 9.8 with the mods you have, doubt a suspension controller that most throw out is going to help you. Good luck
catdad
Lake City
#45
Just looked at it, just did it at the start
Demid22
Nurse
JONESBOROUGH
#46
Ok so you have the very first block in the launch table set to 25% in rear for your friend. But the rest go back to what it shipped with. Gotcha. Prolly helps with the initial shock. You played around in the velocity table at all? Shew. Things get complicated quick in there.
catdad
Lake City
#47
No, that the only change Ive made. Ill look at it some more after I get my car running again. I tried to load demon170 parameters with the hp os patch and car runs like crap, but my e60 tune runs great. Hopefully have it figured out in a couple hours
Demid22
Nurse
JONESBOROUGH
#48
Hell yea brother. Good luck to ya.
#49
Been trying to find tangible information on these but am coming up short. Does anyone have real world 60’ times from the track using this controller? Has anyone adjusted it using the software? Are bricking issues still a concern? Good product or gimmick?
I’ve had one in my Hellcat and Redeye since they were first released. I’ve had no issues. I don’t track my cars but we do get in a lot of spirited driving. IMVHO it’s was money well spent.
#50
What brand?
#51
2ndgen
Orem
Diablo. Is there another?
DSC is the only one that makes one.
DSC sells it directly with their own tunes and tuner software for it.
Diablo Sport private labels and resells it with their own tunes and tuning software for it.
So, two options to get the "same" thing.
#53
Well diablo and dsc I believe. Think the diablo is discontinued and the dsc is still available
The diablo one isn't good, had alot of problems wid it
The latest Gen Diablo Sport unit has been problem free to my knowledge at least. I had one of their first units out and it worked great improve my street 0 to 60 quarter-mile time and 60 to 130 times. It shit to bed and gave me suspension controller fault I sent it to Diablo and they replaced it for free with the latest generation unit, which has been working great since, I found that pretty good customer support of theirs to take a unit that I purchased three years ago and still cover under warranty and replace it with the latest generation. I would recommend a Diablo Sport one, Especially if it’s the only one you could get anymore.
#55
The one from holley/diablosport?
#56
You can still get a DSC unit for a Challenger and also one for a Grand Cherokee/Trackhawk.
Demid22
Nurse
JONESBOROUGH
#59
https://dodgeforum.com/articles/challenger-demon-gets-drag-mode-drag-suspension/
Somenadditional info confirming demons drag mode firms up the rear and loosens the front.
Still playing with my settings to get the besr percentage seeing as we can adjust it from 0%-100%
I already know full 100% firm in the rear will blow the tires off unless you are dead hooked.
