- JONESBOROUGH
- TN
- 2017 Dodge Challenger Hellcat
Very impressed with the conversations in this thread. Clearly, this forum has a more mechanical mindset than the other place....
Regardless, my goals here are slightly different than the ET numbers being thrown around here (as impressive as they are).
Mine is a 2016 M6 daily driver. I'm a relative newcomer to the Hellcat world, but not to cars and tuning.
My problem is, this car doesn't really feel any faster than some of the other cars I've owned.
I'm currently building a bottom end to drop in the car and I plan to top it with a 3.0 Whipple.
I plan on doing a built transmission at the same time I do the engine swap, so it's a big project.
My question with the Whipple on the stock bottom end was more about do I need to burn money on porting/snout/TB to support the current 2.4L or can I just put that money straight to the Whipple and drop that in the car now.
I'm sure the car will make a few passes down the strip as part of TnT (most of my cars do), but my larger goals are healthy logs with improved performance from what I have now.
When I swap the engine and trans, that's when I'll get significantly more aggressive.
This is running triple pumps returnless and 1650 injectors. Catless Longtubes.
