How difficult is it going from a HP tuners tune to a Diablo tune?
TEXAS REDEYE
PASADENA
2019 HELLCAT RED EYE
Can they use the same PCM and just write over the tune, or would it require a new PCM with a brand new tune?
TEXAS REDEYE
TEXAS REDEYE
PASADENA
Thread Starter #2
99 views and no answers. I didn't think this question was that difficult.
Most (like me) want to go the opposite way. I used my buddy’s HPT to pull and read my DS based tune because you can see and do more with HPT so I’ve heard at least. Why you wanting to go the opposite way?
TEXAS REDEYE
TEXAS REDEYE
PASADENA
I'm more comfortable using SCT and Diablo than HP Tuners. Nothing more. Perhaps one night I can hook up with a HP Tuners brother, get a quick schooling on it, then pay the $300 for the interface and cables.
I’d have to listen in on that conversation too as I’ve never personally used HPT either
I would be careful swapping between different tune platforms ,at my shop I have seen where people swapped tune platforms and because of files are left from the previous weird issues started to arise ,car would run great one moment then run like crap the next and after a lot of frustration the problem was the pcms had file left over in it that could not be erased we have since seen this issue 3 more times ,,now my understanding is that hptuner is not married to our pcm so changing to diablo may not be a problem but im not sure if that's true,i would get a replacement pcm that hasnt been tuned
K
Kat von Himmel
Guest
How is an HPT superior? I'm all ears, especially for details, not generalities. More points of data per RPM/MAP/throttle curve?
I wouldn’t say it is superior but it’s user friendly for sure but both tuner set ups still give good results
FFBOS
Mount Prospect
2016 Hellcat Charger
HP doesn’t offer a handheld that you can load tunes, datalog, etc.
It all has to be done via laptop.
This is what Diablo has going for it.
Following.
MaxCarnage
Spokane Valley
19' Redeye
HPT from what I've seen can sometimes get updates faster with new adjustments. Does anyone know if Diablo will read ethanol content and display it like HPT does? Imo, they are both good. The key is finding the tuner you like and they will likely decide on the tuning software.
That said I know there has been some that went from one to the other. Sorry I'm not much help, I'm still stock, lol.
I think the idea here is DIY
FFBOS
Mount Prospect
It doesn't read ethanol content. I still am a huge advocate for knowing what is going into the tank prior to fill. Been doing it this way for a couple years now with pump e85.
Hemituner
Bayshore
2018 Demon
You can use the same pcm you just need it to have a different unlock. I do the conversion set you up with a trinity and even make it so your current tuned file is the backup file. You would not have to start from scratch.
Hope this helps
AJ
Hope this helps
AJ
You can convert a DS tune into a HPT tune without retuning the car?
K
Kat von Himmel
Guest
Doesn't a laptop offer a larger set of features to the user than a handheld? I wouldn't mind keeping a laptop in the car for that purpose. Kind of a set of electronic wrenches, so to speak.
Hemituner
Bayshore
2018 Demon
We sure can.
Thanks
AJ
MaxCarnage
Spokane Valley
19' Redeye
I'd prefer to get as much info as possible. Read it before putting it in the tank and after. Something doesn't look right, just keep it in a flex tune, until you can make sure your E content is correct. I just prefer having more data than less. Although if things go well from my E85 source, it shouldn't be a problem for me.
