- Astoria
- OR
- 2019 widebody Redeye
So, I recently bought a set of 18 x 11 Forgestar D5 beadlocks and installed Mickey thompson street et r drag radials.
There was a definite learning curve.
I used Dawn and hot water to lube the beads prior to installation and I think there has to be a better lubricant for this.
Tire slipped on okay but it was too cold (40 degrees) out in the shop to get the ring on so I had to bring it in the house to warm up.
Wife wasn't thrilled.
But, I was able to get the ring on by putting my knees on the tire and pushing the bead down once it warmed up.
I would have liked to have a tire shop do this but the shops around here will not touch beadlocks.
Once I got it all put together(with the help of youtube) I found the tires are going to be too short(26"s tall with a circumference of 84") and decided to get a little taller tire.
The tires I bought are Mickey Thompson street et R's 325/35R18 were supposed to be 27's tall but turn out to be 26's tall.So I decided to get the taller tires,305/45R18 and return the other tires.
Getting the tires off the wheels at home proved to be a challenge.
I ended up having to use a forklift to break the bead and a strap and a hoist to pull the tire off the wheel.
I used the forks on the lift with a load on them to push the bead off the rim.
Anyway, without tire shop equipment this is a challenge!
I need to get some good bead lube that evaporates.
I hope this info helps.
