Thread Starter
#61
- memphis
- TN
- 2016 challenger hellcat
Thread Starter
#61
Unless they have some sources that use thinner plates to increase the clutch pack capacity I don’t see much more that can be done , coleen steels would be helpful but I wasn’t able to find any for this unit but thinner steels can sometimes be counter productive because the steels also play a part in the cooling of the clutches the c clutch steels are thick I wish the e and d clutch steels were ,
The Valvebody i guess is a possibility but when you start messing with the calibration of these units it usually doesn’t work at all and builders run into shift timing issues like not shifting at all or too much overlap or bind ups between shifts
1
