How to did track prep off car?
Hey guys, any pointers on the best way to get sticky track prep off the car? Tried alcohol, tried goof off. Open to suggestions
I use bug n tar remover, let it set for the time in the instructions. then using a blue paper towel wipe from top to bottom in vertical motion push the shit to the bottom. do this TWICE! then clean as normal
U
I use Simonize bug and tar remover. (It's what I had) I apply it and let it sit for a few seconds. Then wipe off and wash afterwards.
I also spray the 1/4's with Stoner's trim shine at the track to help with clean up. Then clean with a spray detailer, followed by the b&T remover.
U
I have so much in the car it’s insane
WD40.
U
U
Stuff was like melted gum
The Stoners trim shine helps a bunch. I have very little to clean up with the B&T remover.
I also spray it on my wheel liners and inside the back bumper. Makes it much easier to clean. With as many passes as my car has it would weigh more than a Charger by now.🤣
Hatermkr
West bend
2016 helldemon
Wax and grease remover.
Our track must not use it since I never find it on my car. Having splash guards does hurt either
Try coating the wheelwells with original PAM.
WD40 is great for removing rubber off the quarters without hurting the finish. Wash off with soapy water afterwards
sc4.6
Port Stanley
Challenger Redeye
I use Geddex Burnout Guard for track days; you can get the rubber off with a pressure washer if using this stuff.
https://www.summitracing.com/parts/ged-321
Trackhawk, RS3, Golf R
If u PPF that area the shit comes right off with WD40
U
Wow lots of great tips here guys keep ‘em coming!
U
U
I have some spare PPF slivers, I used a little around my wheels weeks when I put the flares on so they didn’t damage the paint underneath. Maybe I’ll put some
On there next time and just rip it off. Probably would look better than painters tape
