- Interwebs
- TN
- Demon 170
I dialed my tune in during the middle of summer when it was 95 deg F and 80% humidity. I always use Shell 93 fuel for the street tune. I had the IAT modifier setup properly and it would remove a tick or two of timing as IATs climbed and things looked great in the data logs at WOT with zero STKR ever.
I went to confirm the tune now that it's cooling off. Put in a little over half a tank of Shell 93 from my usual place. Made a couple WOT pulls and log showed a degree or so of STKR in a couple spots. Hmmm. Lambda/AFR, boost, fuel pressure, everything else was the same as summer logs. Not a big deal but not what I expected as I figured in cool 60 degree air I'd be less prone to STKR than in 95 degree air. I thought maybe something up with the gas so I drove it out and a week or so later put in more Shell 93 from my usual spot. Re-tested, same tick of STKR in a couple spots.
So I read up on winter blend fuel and it seems it's mixed a bit differently to account for really cold areas in order to aid in cold starting. The fuel is a bit more volatile as a result and more prone to knock. So I removed .5 deg from my tune in a couple spots and good to go. I could have left it but I don't like to see more than .5 deg of STKR in a spot or two in a log and I was seeing 1 deg at around 5800 and again at 6300. My knock sensors thresholds are all stock except for 4,000, 4300, and 4700 RPM and 1.4 air charge where they're increased a tick from race fuel testing to get them dialed in and avoid false knock from supercharger noise.
May be common knowledge for some here but thought I'd mention it just the same.
1
1
