- Middleville
- MI
- 2016 Charger Hellcat
So what you guys are saying that my .500 reaction time is not that good .. and here i thought halt a second was good
@moparjim that ATI damper is worth the money .. it does a much better job at controlling vibrations VS the stock cast piece. I don't trust any stock damper .. I have seen way too many come apart or beat up bearings ,etc in the engine .
The removal of the sway bar cause traction issues .. The front jumps up really quickly then falls right back down just as fast unloading the rear tires .. I have seen this many times . If weight is the concern get the one from the demon that's what I did . 7 lbs VS 20lbs .
I was looking at the lighter 1320 bar but the Chargers already come with a lighter one. With end links mine is 14 lbs and a 1320 may have been 10-12. I know it wasn't enough to go buy one. The Challengers are in the 20 lbs range though
1
