Uconnect 18.43.01 OTA Update
I've been updating my Jeep and Hellcat with the convoluted flash drive download that involves sitting in the running car for 20 minutes, opening and closing the driver's door when finished, waiting for system to go back to sleep and then finally exiting the vehicle.
Last night, I got the Over the Air update message for the Cat after parking it in the garage. I just pressed OK, went in the house and the system updated all by itself. Seemed to work perfectly. That said, I can't tell anything that is different. Maybe the stereo sounds a bit better with less of a upper mid-range glare that has always annoyed me.
Humm, I've not seen anything yet.
Diboblo
Riverside
2015 Dodge Charger Hellcat!
Just got my OTA UConnect update.
Nothing noticeable has changed. No glitches.
I'll have to check to see if the IAT vs Inercooler Temp gauge swap was fixed...
Bob
Bob
Not sure how they roll these out but I’ve not gotten mine yet.
Diboblo
Riverside
Update: I/C temp & IAT swap not resolved, in this update :(
It was a UConnect update that messed it up... when are they going to fix this? Ugh...
Bob
Riverside, California
Bob
@DodgeCares this has been an issue for well over 18 months now. The gauges worked correctly, then got 'switched' in a Uconnect update.
As an ex-IT guy, I know this has to be a simple fix to (at most) 2 lines of code !!
Why can't we get this fixed ??
06SRT10NR
Knobnation
got the latest OTA update as well a couple weeks ago ['15 M6]. no audio for two days, eventually started working again. otherwise no obvious changes.
the obnoxious Speed adjusted audio crap is still a problem, still have to turn it on, then off again before moving, to keep it from screwing with the volume. I've forgotten how many years it's been now since the update that broke it
Applied to my Cat, no obvious changes other than it seems to have broken the radio - no reception on FM or AM :mad:
Wondering just how screwed I am since my 3/36 has expired. Thanks for another great update Uconnect (n)(n)
No OTA update on my 2015 yet. Also no on line up date available. 🤨
Seriously?!
You're going to make me go check mine now.
:eek:
Well, most importantly, my radio still works (AM/FM)
But I feel left out in a strange way, my radio just recently updated, but not to 18.43.01
Maybe I should be grateful???
Wonder if the update didn’t take. You’re two versions behind.
Mine hasn’t updated in awhile and its
So much for OTAs
I’m starting to think these OTA’s are regional.
Yeah, the "NAFTA" thing has me scratching my head...
WTH?
It’s telling me the update available is the one I have 😂.
https://www.driveuconnect.com/support/software-update.html
Yeah, I'm finding that number oddly old...
Something about my VIN doesn't qualify??? The link above says I only qualify for "17.43.01 NAFTA", released in 2018-03-23
17.43.01 is the last one to be offered for download. 18.43.01 is OTA only. I do think the OTAs are being rolled out regionally. My ‘14 Jeep and ‘16 HC were updated within days of each other.
