- Pasadena
- MD
- 2015 Challenger SRT Hellcat
So I have decided to take the car off of ANN, last season was great but I would like to move away from race gas and move to E85. In order for me to do that I have to convert the car from ANN and use the VE tables. So to get started I did the following in my tune:
Then I went for a quick drive around the block but as you can see the graph wasn't populating at all with data.
So I noticed that STFT were way off the reservation and so then I changed my histograms for the logging to be use the LTFT+STFT for part throttle and I started to get a lot more data populated.
However I can't tell what is the proper way to setup of the histogram. If anyone would like to contribute to this thread please do so. I plan on this being an open source knowledge share so individuals that want to switch to using the VE tables and tune using community knowledge won't be afraid to do so. Also I went to HP Tuners site and looked in the Mopar section and could not find a good example of how individuals were logging this data to make corrections. They have a great Inj. PW vs Fuel Mass article but nothing regarding this topic. Even checked @Speedy! old youtube vidya's but couldn't find anything either. For all the protections that I disabled, it is important that when you have finished your tuning cycle to return all those values back, I saved mine in an excel spread sheet. It is also important to understand that you do not go above 50% throttle or 4000 RPM when doing part throttle tuning.
- Disabled ANN (Engine -> Airflow -> Neural Network -> General)
- Zeroed out Power Enrichment tables (save default values, Engine -> Fuel -> Power Enrich -> Power Enrichment)
- Disabled COT Protection (Engine -> Fuel -> Temp. Control -> Catalyst Protection)
- Disabled DFCO (Engine -> Fuel -> Cutoff, DFCO -> Deceleration Fuel Cutoff, set to 300).
![1640552552919.png](/data/attachments/60/60186-1fd18e0772d51f192c9cf21457851c3f.jpg)
![1640552631417.png](/data/attachments/60/60187-0960e0f82f32632604309da1ab67e131.jpg)
![1640552885520.png](/data/attachments/60/60188-06fbf7315ae64219174aed89741795a9.jpg)
4
