Counter Measure Upgrades
It was time....
When you tapped into the mirror connector, did you literally just push the power tap pins into the existing pins in the connector?
You're not worried about them slipping loose?
LonestarHellcat
Great video and goodluck to Mrs Speedy
Those DFR7's are a heck of a buy, I got 2 a few months ago & love 'em.
Good luck to Mrs. Speedy !!!
They stick in there pretty darn tight. Never had any come loose in 10 years of using this type of setup. Depending on the connector, sometimes you have to release a locking tab just to make room, then re-seat once hooked up. Had to do that in the Mrs. new ride.
YMMV
Morris Co
18 Charger HC
That's all I had to do as well when I installed my R7 w/ the mirror tap. They have different size pins/wire so make sure you choose wisely. :) Other than that, easy peasy.
