MY BEST ET WAS ACTUALLY 6.47@111MPH BEST 60FT WAS 1.47 ALSO
I had to pull timing as the day went on because we kept spinning but I did see some data on the logs that had more timing added that looked very promising when the sun came out the track actually got better and I wished I had put the timing back in but didn't get around to it as I was actually racing at that point , I alos learned that when I went back to my original race gas tune I was loosing boost right before going into 3rd ,logs didn't show any reason other then I had a check engine light pop up for (p025d fuel pump control module circuit high) ,yesterday I just kept clearing the fault I didn't get it in my earlier logs because I had deleted it in my tunes ,when I went into the tune and deleted the p025d fault so it wouldn't pop the engine light on it fixed the boost loss ,the reason im sharing this is because I have a bap ,if you don't delete that fault in the tune it will cause that problem with boost loss ,I saw it in the two passes right after I switched back to the tune ,the bap will effect that because it creates more resistance in the circuit to bring the pump pressure up
